Commit b3b5ee38 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- added routineTest9 covering a bug found at the ESSOESW summer school
parent 506a7acd
* $Id$
* Copyright (C) INRIA, 2008
* Copyright (C) INRIA, 2008-2009
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
......@@ -38,7 +38,7 @@ import org.semanticweb.owl.align.Evaluator;
import fr.inrialpes.exmo.align.impl.renderer.RDFRendererVisitor;
import fr.inrialpes.exmo.align.impl.method.StringDistAlignment;
import fr.inrialpes.exmo.align.impl.method.StringDistances;
import fr.inrialpes.exmo.ontosim.string.StringDistances;
import fr.inrialpes.exmo.align.impl.eval.PRecEvaluator;
import fr.inrialpes.exmo.align.impl.BasicParameters;
import fr.inrialpes.exmo.align.impl.URIAlignment;
......@@ -79,7 +79,7 @@ $ java -jar lib/Procalign.jar file://$CWD/examples/rdf/edu.umbc.ebiquity.publica
assertEquals( alignment.nbCells(), 0 );
alignment.init( new URI("file:examples/rdf/edu.umbc.ebiquity.publication.owl"), new URI("file:examples/rdf/edu.mit.visus.bibtex.owl"));
alignment.align( (Alignment)null, params );
assertEquals( alignment.nbCells(), 43 );
assertEquals( alignment.nbCells(), 44 );
FileOutputStream stream = new FileOutputStream("test/output/bibref.rdf");
PrintWriter writer = new PrintWriter (
new BufferedWriter(
......@@ -104,39 +104,16 @@ $ java -jar lib/Procalign.jar file://$CWD/examples/rdf/edu.umbc.ebiquity.publica
//assertEquals( stream.toString().length(), 1740, "Rendered differently" );
@Test(groups = { "full", "Noling" })
public void tokenizeTest() throws Exception {
Vector<String> res = StringDistances.tokenize( "ComputerScience" );
// [Computer, Science]
assertEquals( res.size(), 2 );
assertEquals( res.get(1), "Science" );
res = StringDistances.tokenize( "FullProfessor in ComputerScience" );
// [FullProfessor, in, ComputerScience]
assertEquals( res.size(), 3 );
assertEquals( res.get(1), "in" );
res = StringDistances.tokenize( "USofAmerica" );
// [USof, America]
assertEquals( res.get(1), "America" );
res = StringDistances.tokenize( "SpiritofAmerica" );
// [Spiritof, America]
res = StringDistances.tokenize( "SpiritOfAmerica" );
// [Spirit, Of, America]
assertEquals( res.get(1), "Of" );
res = StringDistances.tokenize( "ProtoDL" );
// [Proto, DL]
assertEquals( res.get(1), "DL" );
res = StringDistances.tokenize( "And/or" );
// [And, or]
assertEquals( res.get(1), "or" );
res = StringDistances.tokenize( "title: FullProfessor" );
// [title, FullProfessor]
assertEquals( res.get(1), "FullProfessor" );
/* This tests an error when the distance name is incorrect */
@Test(groups = { "full", "impl", "noling" }, expectedExceptions = AlignmentException.class)
public void routineTest9() throws Exception {
Parameters params = new BasicParameters();
params.setParameter( "stringFunction", "teinDistance");
params.setParameter( "noinst", "1");
alignment = new StringDistAlignment();
assertNotNull( alignment, "ObjectAlignment should not be null" );
