Commit a9d0e4de authored by Jérôme Euzenat's avatar Jérôme Euzenat
- developed more systematic and elegant generator
parent 22066fb8
......@@ -20,9 +20,9 @@
* Generates the OAEI Benchmark dataset from an ontology
* It can generate it in a continuous way (each test build on top of a previous one)
* or generate tests independently.
* Generates a "discriminant" set of tests by systematically covering the
* space at a particular resolution (STEP)
* This only applies to three different dimensions but could be parameterized
package fr.inrialpes.exmo.align.gen;
......@@ -39,159 +39,41 @@ public class DiscriminantGenerator extends TestSet {
secondOntoFile = params.getProperty( "outdir" )+"/000/onto.rdf";
// Test configuration parameters
int maximum = 5;
float incr = 0.2f;
String mod = params.getProperty( "modality" ); // "mult"
boolean multModality = (mod != null && mod.startsWith( "mult" ));
String hard = params.getProperty( "increment" );
int STEP = 5;
String stepval = params.getProperty( "step" );
try {
if ( hard != null && !hard.equals("") ) incr = Float.parseFloat( hard );
if ( stepval != null && !stepval.equals("") ) STEP = Integer.parseInt( stepval );
} catch ( Exception ex ) {
ex.printStackTrace(); // continue with the default
String max = params.getProperty( "maximum" );
if ( max != null ) maximum = Integer.parseInt( max );
if ( debug ) System.err.println( " Mod: "+mod+" / Incr: "+incr+" / Max: "+maximum );
final float INCR = 1.0f/(STEP-1);
if ( debug ) System.err.println( " STEP: "+STEP+" / INCR: "+INCR );
/* Test 000 Generate the initial situation */
root = initTests( "000" );
float i1 = 0.0f;
/* Iterator for gradual change
for ( int i = 0; i1 < 1.00f && i < maximum ; i++ ) { //
if ( i > 0 ) PREVTEST = "201"+SUFFIX; // The previous suffix
if ( !multModality ) i1 += incr; // traditional
else i1 += (1. - i1) * incr; // hardened
//if ( debug ) System.err.println( " ******************************************************** "+i+": i1 = "+i1 );
if ( i1 < 1.0f ) {
SUFFIX = "-"+(i+1)*2; //((Float)i1).toString().substring(2, 3); // 2 4 6 8
} else {
SUFFIX = "";
for ( int i = 0; i < STEP; i++ ) {
String label1 = i+"00";
if ( i != 0 ) {
addTestChild( "000", label1,
newProperties( ParametersIds.REMOVE_PROPERTIES, ""+i*INCR ) );
final String FIRST1 = "0.25f";
final String HALF = "0.5f";
final String MORE3 = "0.75f";
// Then FULL
// Degradation is 4* .25
/* 004-x *** no names */
addTestChild( "000", "001",
newProperties( ParametersIds.RENAME_CLASSES, FIRST1,
ParametersIds.RENAME_PROPERTIES, FIRST1 ) );
addTestChild( "000", "002",
newProperties( ParametersIds.RENAME_CLASSES, HALF,
ParametersIds.RENAME_PROPERTIES, HALF ) );
addTestChild( "000", "003",
newProperties( ParametersIds.RENAME_CLASSES, MORE3,
ParametersIds.RENAME_PROPERTIES, MORE3 ) );
addTestChild( "000", "004",
newProperties( ParametersIds.RENAME_CLASSES, FULL,
ParametersIds.RENAME_PROPERTIES, FULL ) );
/* 044 *** no names + no comments */
addTestChild( "004", "014",
newProperties( ParametersIds.REMOVE_COMMENTS, FIRST1 ) );
addTestChild( "004", "024",
newProperties( ParametersIds.REMOVE_COMMENTS, HALF ) );
addTestChild( "004", "034",
newProperties( ParametersIds.REMOVE_COMMENTS, MORE3 ) );
addTestChild( "004", "044",
newProperties( ParametersIds.REMOVE_COMMENTS, FULL ) );
/* 040 *** no comments */
addTestChild( "000", "010",
addTestChild( "000", "020",
addTestChild( "000", "030",
addTestChild( "000", "040",
/* 044 *** no comments */
addTestChild( "040", "041",
addTestChild( "040", "042",
addTestChild( "040", "043",
/* 440 *** no comments */
addTestChild( "040", "140",
newProperties( ParametersIds.REMOVE_PROPERTIES, FIRST1 ) );
addTestChild( "040", "240",
newProperties( ParametersIds.REMOVE_PROPERTIES, HALF ) );
addTestChild( "040", "340",
newProperties( ParametersIds.REMOVE_PROPERTIES, MORE3 ) );
/* 400 *** no property */
addTestChild( "000", "100",
addTestChild( "000", "200",
addTestChild( "000", "300",
addTestChild( "000", "400",
newProperties( ParametersIds.REMOVE_PROPERTIES, FULL ) );
/* 270 *** no property + no instance */
addTestChild( "004", "104",
addTestChild( "004", "204",
addTestChild( "004", "304",
addTestChild( "004", "404",
addTestChild( "400", "401",
addTestChild( "400", "402",
addTestChild( "400", "403",
/* 444 *** no property + expand */
addTestChild( "404", "414",
addTestChild( "404", "424",
addTestChild( "404", "434",
/* 280 *** no property + expand */
addTestChild( "400", "410",
addTestChild( "400", "420",
addTestChild( "400", "430",
addTestChild( "400", "440",
addTestChild( "440", "441",
addTestChild( "440", "442",
addTestChild( "440", "443",
/* 250-x *** no names + no comments + no property */
addTestChild( "044", "144",
addTestChild( "044", "244",
addTestChild( "044", "344",
addTestChild( "044", "444",
for ( int j = 0; j < STEP; j++ ) {
String label2 = ""+i+j+"0";
if ( i != 0 || j != 0 ) {
addTestChild( label1, label2,
newProperties( ParametersIds.REMOVE_COMMENTS, ""+j*INCR ) );
for ( int k = 0; k < STEP; k++ ) {
String label3 = ""+i+j+k;
if ( i != 0 || j != 0 || k != 0 ) {
addTestChild( label2, ""+i+j+k,
newProperties( ParametersIds.RENAME_CLASSES, ""+k*INCR,
ParametersIds.RENAME_PROPERTIES, ""+k*INCR ) );
