Commit a008f4eb authored by Jérôme Euzenat's avatar Jérôme Euzenat
- added google chart API support (-t html)
parent 91f1e7ce
...@@ -20,7 +20,9 @@ ...@@ -20,7 +20,9 @@
* USA. * USA.
/* This program evaluates the results of several ontology aligners in a row. /*
* This program evaluates the results of several ontology aligners and plot
* these results
package fr.inrialpes.exmo.align.util; package fr.inrialpes.exmo.align.util;
...@@ -55,8 +57,7 @@ import gnu.getopt.Getopt; ...@@ -55,8 +57,7 @@ import gnu.getopt.Getopt;
import fr.inrialpes.exmo.align.parser.AlignmentParser; import fr.inrialpes.exmo.align.parser.AlignmentParser;
* A basic class for synthesizing the alignment results of an algorithm by a * A basic class for ploting the results of an evaluation.
* precision recall graph.
* These graphs are however computed on averaging the precision recall/graphs * These graphs are however computed on averaging the precision recall/graphs
* on test directories instead of recording the actual precision recall graphs * on test directories instead of recording the actual precision recall graphs
...@@ -243,6 +244,8 @@ public class GenPlot { ...@@ -243,6 +244,8 @@ public class GenPlot {
// Vector<Pair> -> . // Vector<Pair> -> .
if ( type.equals("tsv") ){ if ( type.equals("tsv") ){
printTSV( toplot ); printTSV( toplot );
} else if ( type.equals("html") ) {
printHTMLGGraph( toplot );
} else if ( type.equals("tex") ) { } else if ( type.equals("tex") ) {
printPGFTex( toplot ); printPGFTex( toplot );
} else System.err.println("Flag -t "+type+" : not implemented yet"); } else System.err.println("Flag -t "+type+" : not implemented yet");
...@@ -435,8 +438,8 @@ public class GenPlot { ...@@ -435,8 +438,8 @@ public class GenPlot {
writer.println("%% Include in PGF tex by:\n"); writer.println("%% Include in PGF tex by:\n");
writer.println("%% \\begin{tikzpicture}[cap=round]"); writer.println("%% \\begin{tikzpicture}[cap=round]");
writer.println("%% \\draw[step="+(STEP/10)+"cm,very thin,color=gray] (-0.2,-0.2) grid ("+STEP+","+STEP+");"); writer.println("%% \\draw[step="+(STEP/10)+"cm,very thin,color=gray] (-0.2,-0.2) grid ("+STEP+","+STEP+");");
writer.println("%% \\draw[->] (-0.2,0) -- (10.2,0) node[right] {$recall$}; "); writer.println("%% \\draw[->] (-0.2,0) -- (10.2,0) node[right] {$"+xlabel+"$}; ");
writer.println("%% \\draw[->] (0,-0.2) -- (0,10.2) node[above] {$precision$}; "); writer.println("%% \\draw[->] (0,-0.2) -- (0,10.2) node[above] {$"+ylabel+"$}; ");
writer.println("%% \\draw plot[mark=+,smooth] file {"+algo+".table};"); writer.println("%% \\draw plot[mark=+,smooth] file {"+algo+".table};");
writer.println("%% \\end{tikzpicture}"); writer.println("%% \\end{tikzpicture}");
writer.println(); writer.println();
...@@ -451,6 +454,60 @@ public class GenPlot { ...@@ -451,6 +454,60 @@ public class GenPlot {
* This does average plus generate the call for Google Chart API
public void printHTMLGGraph( Vector<Vector<Pair>> result ){
output.print("<img src=\"http://chart.apis.google.com/chart?");
output.print("chs=600x500&cht=lxy&chg=10,10&chof=png");
output.print("&chxt=x,x,y,y&chxr=0,0.0,1.0,0.1|2,0.0,1.0,0.1&chxl=1:|"+xlabel+"|3:|"+ylabel+"&chma=b&chxp=1,50|3,50&chxs=0N*sz1*|2N*sz1*");
output.print("&chd=t:"); // data
boolean firstalg = true;
for( Vector<Pair> table : result ) {
if ( !firstalg ) output.print("|");
firstalg = false;
boolean firstpoint = true;
String Yval = "|";
for( Pair p : table ) {
if ( !firstpoint ) {
output.print(",");
Yval += ",";
firstpoint = false;
Yval += String.format("%1.2f", p.getY()*10);
if ( debug > 1 ) System.err.println( " >> "+p.getX()+" - "+p.getY() );
output.printf( "%1.2f", p.getX()*10 );
output.print( Yval );
output.print("&chdl="); // labels
int i = 0;
//String marktable[] = { "+", "*", "x", "-", "|", "o", "asterisk", "star", "oplus", "oplus*", "otimes", "otimes*", "square", "square*", "triangle", "triangle*", "diamond", "diamond*", "pentagon", "pentagon*"};
//String colortable[] = { "black", "red", "green", "blue", "cyan", "magenta" };
String colortable[] = { "000000", "ffff00", "ff00ff", "00ffff", "ff0000", "00ff00", "0000ff", "888888", "8888ff", "88ff88", "ff8888", "8800ff", "88ff00", "008800", "ff8800", "0088ff", "000088","ff0088","00ff88", "888800", "880088", "008888", "880000", "008800", "000088", "88ffff", "ff88ff", "ffff88" };
String style = "";
String color = "";
for ( String m : listAlgo ) {
if ( i > 0 ) {
output.print( "|" );
color += ",";
style += "|";
output.print( m );
color += colortable[i%28];
if ( !listEvaluators.get(i).isValid() ) {
style += "2";
} else {
style += "2,6,3";
i++;
output.print("&chco="+color); // colors
output.print("&chls="+style); // linestyle
output.println("&chds=0,10\"/>");
// 2010: THIS IS ONLY FOR TSV AND THIS DOES NOT WORK // 2010: THIS IS ONLY FOR TSV AND THIS DOES NOT WORK
// IT IS SUPPOSED TO PROVIDE // IT IS SUPPOSED TO PROVIDE
// List of algo // List of algo
...@@ -473,7 +530,7 @@ public class GenPlot { ...@@ -473,7 +530,7 @@ public class GenPlot {
public void usage() { public void usage() {
System.out.println("usage: GenPlot [options]"); System.out.println("usage: GenPlot [options]");
System.out.println("options are:"); System.out.println("options are:");
System.out.println("\t--type=tsv|tex|(html|xml) -t tsv|tex|(html|xml)\tSpecifies the output format"); System.out.println("\t--type=tsv|tex|html(|xml) -t tsv|tex|html(|xml)\tSpecifies the output format");
System.out.println("\t--graph=class -g class\tSpecifies the class of Evaluator to be used"); System.out.println("\t--graph=class -g class\tSpecifies the class of Evaluator to be used");
System.out.println("\t--evaluator=class -e class\tSpecifies the class of GraphEvaluator (plotter) to be used"); System.out.println("\t--evaluator=class -e class\tSpecifies the class of GraphEvaluator (plotter) to be used");
System.out.println("\t--list=algo1,...,algon -l algo1,...,algon\tSequence of the filenames to consider"); System.out.println("\t--list=algo1,...,algon -l algo1,...,algon\tSequence of the filenames to consider");
