Commit 9e5a9adf authored by Jérôme Euzenat's avatar Jérôme Euzenat
- added getEntityAnnotations with languages
- added more accurate descriptions in comments
parent 5345e0e6
......@@ -31,10 +31,13 @@ public interface LoadedOntology<O> extends Ontology<O> {
* returns the default name of an entity if specified.
* otherwise, returns one of its names (e.g., "rdfs:label" property values)
* otherwise, returns one of its names (e.g., "rdfs:label" property values).
* Which name is returned is unspecified.
* In case no such official name is given to the entity it is possible to
* use the entity URI to return its fragment identifier (after the '#') or
* last fragment (after the last "/" or just before) in this order.
* Because of its low definiteness, it is not advised to use this primitive
* and it is better to use other ones (getNames, getComments, getAnnotations).
* @param o the entity
* @return a label
* @throws OntowrapException
......@@ -44,8 +47,11 @@ public interface LoadedOntology<O> extends Ontology<O> {
* returns the default name of an entity in a language (attribute xml:lang)
* if specified.
* otherwise returns the default name (getEntityName)
* @return a label
......@@ -96,6 +102,17 @@ public interface LoadedOntology<O> extends Ontology<O> {
public Set<String> getEntityAnnotations( Object o ) throws OntowrapException;
* Returns all the values of the "owl:AnnotationProperty" property for a given entity expressed in the required language.
* These annotations are those predefined in owl (owl:versionInfo, rdfs:label, rdfs:comment, rdfs:seeAlso and rdfs:isDefinedBy)
* but also all other defined annotation properties which are subClass of "owl:AnnotationProperty"
* @param lang the code of the language ("en", "fr", "es", etc.)
* @return the set of annotation values
public Set<String> getEntityAnnotations( Object o, String lang ) throws OntowrapException;
public boolean isEntity( Object o );
public boolean isClass( Object o );
public boolean isProperty( Object o );
