Commit 9e44538b authored by Jérôme David's avatar Jérôme David
A first version of a SKOS wrapper made with JENA
parent 3b16d7e5
package fr.inrialpes.exmo.ontowrap.skosapi;
import java.io.File;
import java.net.URI;
import java.util.Collections;
import java.util.HashSet;
import java.util.Set;
import com.hp.hpl.jena.graph.Node;
import com.hp.hpl.jena.rdf.model.InfModel;
import com.hp.hpl.jena.rdf.model.Model;
import com.hp.hpl.jena.rdf.model.ModelFactory;
import com.hp.hpl.jena.rdf.model.RDFNode;
import com.hp.hpl.jena.rdf.model.ResIterator;
import com.hp.hpl.jena.rdf.model.Resource;
import com.hp.hpl.jena.rdf.model.Statement;
import com.hp.hpl.jena.rdf.model.StmtIterator;
import com.hp.hpl.jena.util.iterator.ExtendedIterator;
import com.hp.hpl.jena.vocabulary.RDF;
import com.hp.hpl.jena.vocabulary.RDFS;
import fr.inrialpes.exmo.ontowrap.HeavyLoadedOntology;
import fr.inrialpes.exmo.ontowrap.OntowrapException;
public class JenaSKOSThesaurus implements HeavyLoadedOntology<Model> {
protected final static String SKOS_NS="http://www.w3.org/2004/02/skos/core#";
protected final static String SKOS_CONCEPT=SKOS_NS+"Concept";
protected final static String SKOS_PREFLABEL=SKOS_NS+"prefLabel";
protected final static String SKOS_NOTE=SKOS_NS+"note";
protected final static String SKOS_NOTATION=SKOS_NS+"notation";
protected final static String SKOS_BROADERTRANSITIVE=SKOS_NS+"broaderTransitive";
protected final static String SKOS_NARROWERTRANSITIVE=SKOS_NS+"narrowerTransitive";
protected final InfModel ontoInf;
protected final Model onto;
public JenaSKOSThesaurus(URI file) {
onto=ModelFactory.createDefaultModel();
onto.read(file.toString());
onto.read((new File("/Users/jerome/Recherche/tae/skos.rdf")).toURI().toString());
this.ontoInf=ModelFactory.createRDFSModel(onto);
@Override
public boolean getCapabilities(int Direct, int Asserted, int Named) throws OntowrapException {
// TODO Auto-generated method stub
return true;
@Override
public Set<? extends Object> getClasses(Object i, int local, int asserted, int named) throws OntowrapException {
return Collections.emptySet();
@Override
public Set<? extends Object> getDataProperties(Object c, int local, int asserted, int named) throws OntowrapException {
@Override
public Set<? extends Object> getDomain(Object p, int asserted) throws OntowrapException {
@Override
public Set<? extends Object> getInstances(Object c, int local, int asserted, int named) throws OntowrapException {
@Override
public Set<? extends Object> getObjectProperties(Object c, int local, int asserted, int named) throws OntowrapException {
@Override
public Set<? extends Object> getProperties(Object c, int local, int asserted, int named) throws OntowrapException {
@Override
public Set<? extends Object> getRange(Object p, int asserted) throws OntowrapException {
@SuppressWarnings("unchecked")
public <E> Set<E> getSubClasses(E c, int local, int asserted, int named) {
HashSet<E> sub = new HashSet<E>();
//System.out.println(c);
StmtIterator it =ontoInf.listStatements(null,ontoInf.getProperty(SKOS_BROADERTRANSITIVE),(Resource) c);
while (it.hasNext()) {
Statement st = it.next();
//System.out.println("\t"+st.getSubject());
sub.add((E)st.getSubject());
//System.out.println("\tSUITTE");
it =ontoInf.listStatements((Resource) c,ontoInf.getProperty(SKOS_NARROWERTRANSITIVE),(RDFNode)null);
//System.out.println("\t"+st.getObject());
sub.add((E)st.getObject());
return sub;
@Override
public Set<? extends Object> getSubProperties(Object p, int local, int asserted, int named) throws OntowrapException {
@Override
public Set<? extends Object> getSuperClasses(Object c, int local, int asserted, int named) throws OntowrapException {
HashSet<Object> sub = new HashSet<Object>();
StmtIterator it =ontoInf.listStatements(null,ontoInf.getProperty(SKOS_NARROWERTRANSITIVE),(Resource) c);
sub.add(st.getSubject());
it =ontoInf.listStatements((Resource) c,ontoInf.getProperty(SKOS_BROADERTRANSITIVE),(RDFNode)null);
sub.add(st.getObject());
return sub;
@Override
public Set<? extends Object> getSuperProperties(Object p, int local, int asserted, int named) throws OntowrapException {
public Set<? extends Object> getClasses() throws OntowrapException {
ResIterator resIt = ontoInf.listSubjectsWithProperty(RDF.type, ontoInf.getResource(SKOS_CONCEPT));
return resIt.toSet();
@Override
public Set<? extends Object> getDataProperties() throws OntowrapException {
@Override
public Set<? extends Object> getEntities() throws OntowrapException {
return this.getClasses();
@Override
public Object getEntity(URI u) throws OntowrapException {
try {
return ontoInf.getResource(u.toString());
} catch (Exception e) {
throw new OntowrapException("No Object for URI "+u);
public Set<String> getEntityAnnotations(Object o, String lang, String[] types) throws OntowrapException {
HashSet<String> annots=new HashSet<String>();
ExtendedIterator<RDFNode> it=null;
for (String t : types) {
if (it==null)
it=ontoInf.listObjectsOfProperty((Resource) o,ontoInf.getProperty(t));
else
it.andThen(ontoInf.listObjectsOfProperty((Resource) o,ontoInf.getProperty(t)));
Node n = it.next().asNode();
if (n.isLiteral() && (lang==null || lang.equals(n.getLiteralLanguage()))) {
//System.out.println(n.getLiteralLexicalForm());
annots.add(n.getLiteralLexicalForm());
return annots;
public Set<String> getEntityAnnotations(Object o) throws OntowrapException {
return getEntityAnnotations(o,null);
public Set<String> getEntityAnnotations(Object o, String lang) throws OntowrapException {
return getEntityAnnotations(o,lang,new String[]{RDFS.label.toString(),SKOS_NOTE,SKOS_NOTATION});
public Set<String> getEntityComments(Object o, String lang) throws OntowrapException {
return getEntityAnnotations(o,lang,new String[]{SKOS_NOTE});
public Set<String> getEntityComments(Object o) throws OntowrapException {
return getEntityComments(o,null);
@Override
public String getEntityName(Object o) throws OntowrapException {
return getEntityName(o,null);
@Override
public String getEntityName(Object o, String lang) throws OntowrapException {
try {
return getEntityAnnotations(o,lang,new String[]{SKOS_PREFLABEL}).iterator().next();
throw new OntowrapException("No skos:prefLabel for "+o);
@Override
public Set<String> getEntityNames(Object o, String lang) throws OntowrapException {
return getEntityAnnotations(o,lang,new String[]{RDFS.label.toString()});
@Override
public Set<String> getEntityNames(Object o) throws OntowrapException {
return getEntityNames(o,null);
@Override
public URI getEntityURI(Object o) throws OntowrapException {
try {
return URI.create(((Resource) o).getURI());
throw new OntowrapException("No URI for "+o);
@Override
public Set<? extends Object> getIndividuals() throws OntowrapException {
@Override
public Set<? extends Object> getObjectProperties() throws OntowrapException {
@Override
public Set<? extends Object> getProperties() throws OntowrapException {
@Override
public boolean isClass(Object o) throws OntowrapException {
return ontoInf.contains((Resource) o, RDF.type, ontoInf.getResource(SKOS_CONCEPT));
@Override
public boolean isDataProperty(Object o) throws OntowrapException {
return false;
@Override
public boolean isEntity(Object o) throws OntowrapException {
return false;
@Override
public boolean isIndividual(Object o) throws OntowrapException {
return false;
@Override
public boolean isObjectProperty(Object o) throws OntowrapException {
return false;
@Override
public boolean isProperty(Object o) throws OntowrapException {
return false;
@Override
public int nbClasses() throws OntowrapException {
return this.getClasses().size();
@Override
public int nbDataProperties() throws OntowrapException {
return 0;
@Override
public int nbEntities() throws OntowrapException {
@Override
public int nbIndividuals() throws OntowrapException {
return 0;
@Override
public int nbObjectProperties() throws OntowrapException {
return 0;
@Override
public int nbProperties() throws OntowrapException {
return 0;
@Override
public void unload() throws OntowrapException {
@Override
public URI getFile() {
return null;
@Override
public URI getFormURI() {
return null;
@Override
public String getFormalism() {
return null;
@Override
public Model getOntology() {
return ontoInf;
@Override
public URI getURI() {
return null;
@Override
public void setFile(URI file) {
@Override
public void setFormURI(URI u) {
@Override
public void setFormalism(String name) {
@Override
public void setOntology(Model o) {
@Override
public void setURI(URI uri) {
