GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
9d86566c
9d86566c
15 years ago
Jérôme Euzenat
Downloads
Patches
- tutorial update for version 4.0 (unfinished)
27de74d3
2
2 changed files
html/tutorial/tutorial3/embed.html
+113
-24
113 additions, 24 deletions
html/tutorial/tutorial3/index.html
+10
-7
10 additions, 7 deletions
123 additions
31 deletions
113
24
9d86566c
@@ -61,27 +61,36 @@ $ javac -classpath ../../lib/align.jar:../../lib/procalign.jar -d results Skelet
$ java -cp ../../lib/Procalign.jar:results Skeleton file://$CWD/myOnto.owl file://$CWD/edu.mit.visus.bibtex.owl
</div>
<p>
Now considering the
<abbr>
API
</abbr>
(that can be consulted through
its
thin
<a
href=
"../../javadoc/org/semanticweb/owl/align/Alignment.html"
Javadoc
</a>
for instance), can you modify the Skeleton program so that it performs the following:
</p>
<p>
Now considering the
<abbr>
API
</abbr>
(that can be consulted through its
thin
<a
href=
"../../../javadoc/org/semanticweb/owl/align/Alignment.html"
Javadoc
</a>
</p>
<ul>
<li>
Run two different alignment methods (e.g., ngram distance and smoa);
</li>
<li>
Merge the two results;
</li>
<li>
Trim at various thresholds;
</li>
<li>
Evaluate them against the reference alignment and choose the one with the best F-Measure;
</li>
<li>
Displays it as
<acronym
title=
"The web ontology language OWL"
OWL
</acronym>
Rule
s.
</li>
<li>
</li>
<li>
</li>
<li>
</li>
<li>
</li>
<li>
Displays it as
<acronym
title=
OWL
</acronym>
axiom
s.
</li>
</ul>
<p>
Of course, you can do it progressively.
</p>
<h2>
Call an alignment method
</h2>
<div
class=
"fragment"
$ javac -classpath ../../lib/align.jar:../../lib/procalign.jar -d results MyApp.java
$ java -cp ../../lib/Procalign.jar:results MyApp file://$CWD/myOnto.owl file://$CWD/edu.mit.visus.bibtex.owl > results/MyApp.owl
</div>
<p>
Matching two ontologies is achieved with three steps:
<ul>
<li>
creating an instance of the class implementing the expected method
(implementing the
<tt>
AlignmentProcess
</tt>
interface);
</li>
<li>
providing the two ontologies to match to this instance (
<tt>
init
</tt>
</li>
<li>
calling the matching method (
<tt>
align
</tt>
</li>
</ul>
The matching method takes two arguments: an eventual alignment to
improve on (which can be null) a set of parameters
</p>
<p>
Below, two different methods (
<tt>
StringDistAlignment
</tt>
with two
different
<tt>
stringFunction
</tt>
parameters) are instantiated and run:
<div
class=
"fragment"
// Run two different alignment methods (e.g., ngram distance and smoa)
AlignmentProcess a1 = new StringDistAlignment();
@@ -94,9 +103,23 @@ $ java -cp ../../lib/Procalign.jar:results MyApp file://$CWD/myOnto.owl file://$
params.setParameter("stringFunction","ngramDistance");
a2.align( (Alignment)null, params );
</div>
After this step, the two matching methods have been processed and the
result is available within the alignment instances (
<tt>
a1
</tt>
<tt>
a2
</tt>
</p>
<h2>
Manipulate alignments (merge and trim)
</h2>
<p>
Alignments offer methods to manipulate these alignments. In
particular, it is possible to
<ul>
<li>
clone alignments,
</li>
<li>
invert alignments (change the order of ontologies),
</li>
<li>
merge alignments (put all their correspondences together),
</li>
<li>
trim them under various threshold and threshold modalities.
</li>
</ul>
</p>
<div
class=
"fragment"
// Merge the two results.
@@ -106,17 +129,51 @@ $ java -cp ../../lib/Procalign.jar:results MyApp file://$CWD/myOnto.owl file://$
</div>
<h2>
Evaluating alignments
</h2>
<p>
Alignments can also be evaluated. For that purpose, the API provides
the
<tt>
Evaluator
</tt>
interface. Similarly,
to
<tt>
AlignmentProcess
</tt>
, this interface is called by:
<ul>
<li>
creating an instance of a particular
<tt>
Evaluator
</tt>
taking as
argument a reference alignment and the alignment to evaluate;
</li>
<li>
processing the evaluation (
<tt>
eval()
</tt>
) eventually with a parameter.
</li>
</ul>
</p>
<p>
Below the provided code first creates a parser for loading the
reference alignment, then creates an instance
of
<tt>
PRecEvaluator
</tt>
for computing precision and recall between
the alignment
<tt>
a1
</tt>
above with respects to the reference alignment.
<div
class=
"fragment"
// Evaluate them against the references
// and choose the one with the best F-Measure
AlignmentParser aparser = new AlignmentParser(0);
Alignment reference = aparser.parse( (new File ( "refalign.rdf" ) ) . toURL() . toString());
Evaluator evaluator = new PRecEvaluator( reference, a1 );
Parameters p = new BasicParameters();
evaluator.eval( p );
</div>
As previously, results are stored within the
<tt>
Evaluator
</tt>
object
and are accessed through specific accessors.
</p>
<p>
As an excercise, one could try to trim the alignment
<tt>
a1
</tt>
thresholds of 0., .2, .4, .6, .8, and 1., to evaluate these results
for precision and recall and to select the one with the best
F-measure.
</p>
<div
class=
"button"
<input
type=
"button"
onclick=
"show('qu5')"
value=
"Show result"
<input
type=
"button"
onclick=
"hide('qu5')"
value=
"Hide result"
</div>
<div
class=
"explain"
id=
"qu5"
<pre>
double best = 0.;
Alignment result = null;
for ( int i = 0; i
10
i
2
a1.cut
double
i
)/10
evaluator =
new
PRecEvaluator
reference
a1
@@ -127,22 +184,45 @@ $ java -cp ../../lib/Procalign.jar:results MyApp file://$CWD/myOnto.owl file://$
best = ((PRecEvaluator)evaluator).getFmeasure();
</pre>
</div>
<h2>
Displaying an alignment
</h2>
<div
class=
"fragment"
<p>
Finally, alignments can be displayed through a variety of formats
through the
<tt>
AlignmentVisitor
</tt>
abstraction. Alignment are
displayed by:
<ul>
<li>
creating a
<tt>
PrintWriter
</tt>
in which the visitor will print,
</li>
<li>
creating the
<tt>
AlignmentVisitor
</tt>
on this writer, and
</li>
<li>
rendering the alignment (through the
<tt>
render()
</tt>
metthod).
</li>
</ul>
</p>
<p>
<p>
For instance, it is possible to print on the standard output the
alignment selected at the previous exercise as a set of OWL axioms.
</p>
<div
class=
"button"
<input
type=
"button"
onclick=
"show('qu6')"
value=
"Show result"
<input
type=
"button"
onclick=
"hide('qu6')"
value=
"Hide result"
</div>
<div
class=
"explain"
id=
"qu6"
<pre>
// Displays it as OWL Rules
PrintWriter writer = new PrintWriter (
new BufferedWriter(
new OutputStreamWriter( System.out, "UTF-8" )), true);
AlignmentVisitor renderer = new OWLAxiomsRendererVisitor(writer);
a1
.render(renderer);
result
.render(renderer);
writer.flush();
writer.close();
</pre>
</div>
<h2>
Putting the
m
together
</h2>
<h2>
Putting the
se
together
</h2>
<p>
Do you want to see a possible solution?
</p>
<div
class=
"button"
@@ -194,6 +274,15 @@ $ java -cp ../../lib/Procalign.jar:results MyApp file://$CWD/myOnto.owl file://$
writer.flush();
writer.close();
</pre></div>
<p>
This can be compiled and used through:
</p>
<div
class=
"fragment"
</div>
<p>
The execution provides an insight about the best threshold:
<pre>
Threshold 0.0 : 0.4693877551020408 over 148 cells
@@ -221,9 +310,9 @@ Threshold 1.0 : 0.5151515151515151 over 18 cells
<hr
<small>
<p
style=
"text-align: center;"
http://alignapi.gforge.inria.fr/tutorial/tutorial3/embed.html
</p>
</small>
<div
style=
</div>
<hr
<p>
$Id$
</p>
<div>
$Id$
</div>
</small>
</body>
</html>
This diff is collapsed.
10
7
9d86566c
@@ -140,6 +140,8 @@ of <tt>URIAlignment</tt> implementing <tt>AlignmentProcess</tt>.
<div
class=
"fragment"
package fr.inrialpes.exmo.align.impl;
import java.util.Properties;
import org.semanticweb.owl.align.Alignment;
import org.semanticweb.owl.align.AlignmentProcess;
import org.semanticweb.owl.align.AlignmentException;
@@ -252,11 +254,12 @@ you to implement many more methods and other classes.
<p>
Maybe it is not enough, or not efficient enough.
In this case, the best way is to start from one of our class
implementing
a
lignment
s
implementing
<tt>
A
lignment
</tt>
<ul>
<li><tt>
BasicAlignment
</tt></li>
<li><tt>
URIAlignment
</tt></li>
<li><tt>
ObjectAlignment
</tt></li>
<li><tt>
fr.inrialpes.exmo.align.impl.BasicAlignment
</tt></li>
<li><tt>
fr.inrialpes.exmo.align.impl.URIAlignment
</tt></li>
<li><tt>
fr.inrialpes.exmo.align.impl.ObjectAlignment
</tt></li>
<li><tt>
fr.inrialpes.exmo.align.impl.edoal.EDOALAlignment
</tt></li>
</ul>
and extend it so that it implements your matcher.
This is the example given in the
@@ -358,9 +361,9 @@ The API features a DistanceAlignment abstract class that can be specialised for
<hr
<small>
<p
style=
</p>
</small>
<div
style=
</div>
<hr
<p>
$Id$
</p>
<div>
$Id$
</div>
</small>
</body>
</html>
Loading
Save comment
