Commit 95064cc4 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- simplified comments
parent 1b36f99d
<?xml version="1.0" encoding="iso-8859-1" ?>
<!-- $Id$ -->
<!-- See JEoid : TOTEST now -->
<project name="alignoid" default="compile" basedir=".">
<!-- this is useful but introduces, Xlint:path warnings -->
<filelist id="mujar" dir="../../lib">
<!-- JEoid: maybe check better those which are necessary -->
<!-- would better be a named fileset first -->
<file name="align.jar"/>
<file name="jena/icu4j.jar"/>
<file name="jena/iri.jar"/>
......@@ -101,7 +98,6 @@
<property name="javacargs" value="-deprecation" />
<mkdir dir="classes"/>
<javac deprecation="yes" nowarn="no" verbose="no" srcdir="../../src/" destdir="classes" encoding="iso8859-15">
<!-- JEoid: would be better to be positive rather than negative... -->
<compilerarg value="${javacargs}"/>
<classpath refid="classpath" />
<!-- That would be too simple -->
