GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
8d5d1daa
"README.md" did not exist on "1833b92e40d53fee57d4e83544ac60ccecc8a0ae"
8d5d1daa
14 years ago
Jérôme Euzenat
Downloads
Patches
- enabled Wu-Palmer and gloss-overlap (from Ontosim implementation)
8295fc5c
src/fr/inrialpes/exmo/align/ling/JWNLAlignment.java
+21
-7
21 additions, 7 deletions
21 additions
7 deletions
21
7
8d5d1daa
* $Id$
* Copyright (C) INRIA, 2003-2005, 2007, 2009
-2010
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
@@ -40,11 +40,18 @@ import java.net.URI;
public
class
JWNLAlignment
extends
DistanceAlignment
implements
AlignmentProcess
final
static
String
WNVERS
"3.0"
final
static
int
BASICSYNDIST
final
static
int
COSYNSIM
final
static
int
BASICSYNSIM
2
final
static
int
WUPALMER
3
final
static
int
GLOSSOV
4
protected
class
WordNetMatrixMeasure
extends
MatrixMeasure
protected
JWNLDistances
Dist
null
protected
int
method
public
similarity
false
Dist
new
JWNLDistances
public
void
init
throws
AlignmentException
@@ -65,12 +72,16 @@ public class JWNLAlignment extends DistanceAlignment implements AlignmentProcess
String
s2
ontology2
getEntityName
o2
if
s1
null
s2
null
return
switch
method
case
case
BASICSYNDIST
return
Dist
basicSynonymDistance
s1
s2
case
case
COSYNSIM
return
Dist
cosynonymySimilarity
s1
s2
case
2
case
BASICSYNSIM
return
Dist
basicSynonymySimilarity
s1
s2
case
WUPALMER:
return
Dist
wuPalmerSimilarity
s1
s2
case
GLOSSOV:
return
Dist
basicGlossOverlap
s1
s2
default
return
Dist
s1
s2
@@ -95,19 +106,22 @@ public class JWNLAlignment extends DistanceAlignment implements AlignmentProcess
/** Processing **/
public
void
align
Alignment
alignment
Properties
prop
throws
AlignmentException
int
method
int
method
BASICSYNDIST
loadInit
alignment
sim
getSimilarity
String
wnvers
prop
getProperty
"wnvers"
if
wnvers
null
wnvers
WNVERS
String
function
prop
getProperty
"wnfunction"
if
function
null
if
function
equals
"cosynonymySimilarity"
method
else
if
function
equals
"basicSynonymySimilarity"
method
2
if
function
equals
method
COSYNSIM
else
if
function
equals
method
BASICSYNSIM
else
if
function
equals
"wuPalmerSimilarity"
method
WUPALMER
else
if
function
equals
"glossOverlapSimilarity"
method
GLOSSOV
sim
init
prop
getProperty
"wndict"
wnvers
method
sim
initialize
ontology1
ontology2
alignment
sim
compute
prop
prop
setProperty
"algName"
getClass
function
if
prop
getProperty
"printMatrix"
null
printDistanceMatrix
prop
extract
type
prop
This diff is collapsed.
Loading
Save comment
