GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
82eed0fa
82eed0fa
14 years ago
Jérôme Euzenat
Downloads
Patches
- suppressed useless type field!
1dcf7bed
src/fr/inrialpes/exmo/align/impl/edoal/EDOALRelation.java
+9
-16
9 additions, 16 deletions
9 additions
16 deletions
9
16
82eed0fa
@@ -21,8 +21,6 @@
@@ -21,8 +21,6 @@
package
fr.inrialpes.exmo.align.impl.edoal
package
// JE2009: This is a total mess that must be rewritten wrt Direction
import
org.semanticweb.owl.align.AlignmentException
import
import
org.semanticweb.owl.align.AlignmentVisitor
import
import
org.semanticweb.owl.align.Relation
import
@@ -53,7 +51,7 @@ public class EDOALRelation implements Relation {
* <p>
* <p>
* Enumeration to distinuish the direction of the mapping.
g
* </p>
* </p>
* <p>
* <p>
* $Id$
* $Id$
@@ -62,6 +60,8 @@ public class EDOALRelation implements Relation {
* @author richi
* @author richi
* @version $Revision: 1.10 $
// JE2011: Direction is now totally local here...
// JE2009: THIS SHOULD BE REWRITTEN WITH SUBCLASSES AND NO DIRECTIONS...
/* [JE:22/01/2008]
/* [JE:22/01/2008]
* I make this compliant with 2.2.10 and replacing RDFRuleTYpe
@@ -126,36 +126,27 @@ public class EDOALRelation implements Relation {
visitor
visit
this
visitor
visit
this
* It is intended that the value of the relation is =, < or >.
* But this can be any string in other applications.
protected
String
type
null
protected
Direction
direction
null
protected
Direction
direction
null
/** Creation **/
/** Creation **/
public
EDOALRelation
String
t
throws
AlignmentException
public
EDOALRelation
String
t
throws
AlignmentException
direction
Direction
getRelation
t
direction
Direction
getRelation
t
if
direction
null
throw
new
AlignmentException
"Unknown EDOALRelation : "
t
if
direction
null
throw
new
AlignmentException
t
type
t
/** Creation **/
/** Creation **/
public
EDOALRelation
Direction
d
public
EDOALRelation
Direction
d
type
d
toString
direction
d
direction
d
/** Creation: OLD Stuff should disappear **/
public
EDOALRelation
String
t
Direction
d
public
EDOALRelation
String
t
Direction
d
direction
d
direction
d
type
t
/** printable format **/
public
String
getRelation
public
String
getRelation
return
type
return
direction
toString
@@ -168,6 +159,7 @@ public class EDOALRelation implements Relation {
Direction
newDirection
null
Direction
newDirection
null
if
r
instanceof
EDOALRelation
return
null
if
r
instanceof
EDOALRelation
return
null
String
rType
EDOALRelation
r
getRelation
String
rType
EDOALRelation
r
getRelation
String
type
getRelation
// Compose types
// Compose types
if
type
startsWith
"Class"
newType
"Class"
if
type
startsWith
"Class"
newType
"Class"
else
if
type
startsWith
"Relation"
newType
"Relation"
else
if
type
startsWith
"Relation"
newType
"Relation"
@@ -208,6 +200,7 @@ public class EDOALRelation implements Relation {
/** By default the inverse is the relation itself **/
public
Relation
inverse
public
Relation
inverse
String
type
getRelation
if
type
equals
"Class"
return
new
EDOALRelation
"Class"
direction
if
type
equals
"Class"
return
new
EDOALRelation
"Class"
direction
else
if
type
equals
"ClassRelation"
return
new
EDOALRelation
"RelationClass"
direction
else
if
type
equals
"ClassRelation"
return
new
EDOALRelation
"RelationClass"
direction
else
if
type
equals
"ClassAttribute"
return
new
EDOALRelation
"AttributeClass"
direction
else
if
type
equals
"ClassAttribute"
return
new
EDOALRelation
"AttributeClass"
direction
@@ -230,7 +223,7 @@ public class EDOALRelation implements Relation {
/** Are the two relations equal **/
public
boolean
equals
Relation
r
public
boolean
equals
Relation
r
if
r
instanceof
EDOALRelation
if
r
instanceof
EDOALRelation
return
type
equals
EDOALRelation
r
getRelation
return
getRelation
equals
EDOALRelation
r
getRelation
direction
equals
EDOALRelation
r
getDirection
direction
equals
EDOALRelation
r
getDirection
else
else
return
false
return
false
@@ -238,7 +231,7 @@ public class EDOALRelation implements Relation {
public
int
hashCode
public
int
hashCode
return
5
3
type
hashCode
7
direction
hashCode
return
5
7
direction
hashCode
/** Housekeeping **/
@@ -246,7 +239,7 @@ public class EDOALRelation implements Relation {
/** This is kept for displayig more correctly the result **/
public
void
write
PrintWriter
writer
public
void
write
PrintWriter
writer
writer
print
direction
toString
writer
print
getRelation
This diff is collapsed.
Loading
Save comment
