Commit 7ae04ca9 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- Documented requirements for ExtPRecEvaluator and SemPRecEvaluator
parent 0b1a7473
...@@ -85,7 +85,7 @@ alignments and evaluates the second with respect to the first one (reference). ...@@ -85,7 +85,7 @@ alignments and evaluates the second with respect to the first one (reference).
There are already some implementations available in the Alignment API implementation: There are already some implementations available in the Alignment API implementation:
<dl> <dl>
<dt><tt>PRecEvaluator</tt></dt><dd> implements a classical precision/recall/fallout evaluation as well as the <dt><tt>PRecEvaluator</tt></dt><dd> implements a classical precision/recall/fallout evaluation as well as the
derived measures introduced in \cite{do2002a}. Precision is the derived measures introduced in [Do2002a]. Precision is the
ratio between true positive and all aligned objects; Recall is the ratio between the true positive and all ratio between true positive and all aligned objects; Recall is the ratio between the true positive and all
the correspondences that should have been found. It also provides the correspondences that should have been found. It also provides
derived measures (F-measure, overall, noise, etc.).</dd> derived measures (F-measure, overall, noise, etc.).</dd>
...@@ -108,7 +108,20 @@ The result is here split between the kinds of entity considered (Class/Property/ ...@@ -108,7 +108,20 @@ The result is here split between the kinds of entity considered (Class/Property/
computing precision and recall). It is used by the <a href="aserv.html">Alignment server</a></dd> computing precision and recall). It is used by the <a href="aserv.html">Alignment server</a></dd>
</dl> </dl>
</p> </p>
<p>
<span style="color: red;">Requirements</span>
<ul>
<li><b><tt>ExtPRecEvaluator</tt></b> requires that the two alignments be <tt>ObjectAlignment</tt>.
This can be achived, if possible, by invoking <div class="terminal">al = ObjectAlignment.toObjectAlignment( myAlignment );</div> and
that the OWL-API or JENA (shipped with the Alignment API) be in
your classpath.</li>
<li><b><tt>SemPRecEvaluator</tt></b> <i>in addition</i> requires to have an
OWL reasoner in the classpath. In our case, it uses both IDDL and HermiT
(shipped with the alignment API).</li>
</ul>
The class path requirements apply to all command-line primitive below
as well as the Alignment server.
</p>
<h2>Batch evaluation</h2> <h2>Batch evaluation</h2>
