Commit 7a26d3a9 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- release 2.2
parent 9bb3f04f
Loading
...@@ -20,7 +20,6 @@ ...@@ -20,7 +20,6 @@
<li>Integrating tagging to the wordnet stuff</li> <li>Integrating tagging to the wordnet stuff</li>
<li>Improve the metadata</li> <li>Improve the metadata</li>
<li>Build on unit tests</li> <li>Build on unit tests</li>
<li>Consider the new release of OWL-API</li>
</ul></p> </ul></p>
<h2>Under development</h2> <h2>Under development</h2>
...@@ -30,18 +29,35 @@ ...@@ -30,18 +29,35 @@
<h2>Current SVN trunk version</h2> <h2>Current SVN trunk version</h2>
<!--p><b>Version 2.2: /2006 - may GForge be with you</b></p--> <!-- p><b>Version 2.3: /2006 - </b></p-->
<p><ul compact="1">
<p>
<ul compact="1">
<!--li></li-->
</ul></p>
<h2>June 5th, 2006</h2>
<p><b>Version 2.2: 05/06/2006 - Onyeari's version a.k.a. may GForge be with you</b></p>
<p>Upgraded to OWL-API 06-04-12<br />
<font color="red"></font> No problem encountered.
</p>
<p>New version featuring:
<ul compact="1">
<li>Moved sources to gforge.inria.fr</li> <li>Moved sources to gforge.inria.fr</li>
<li>Moved web site to alignapi.gforge.inria.fr</li> <li>Moved web site to alignapi.gforge.inria.fr</li>
<li>Updated documentation to reflect new source location</li> <li>Updated documentation to reflect new source location</li>
<li>Added service directory, alignsvc.jar and QueryMediator class</li>
<li>Revisited the release target of the build file for svn compatibility</li> <li>Revisited the release target of the build file for svn compatibility</li>
<li>Reengineered StringDistances (only return normalized values) and <li>Reengineered StringDistances (only return normalized values) and
StringDistNameAlignment (replaces all the others). These fully StringDistNameAlignment (replaces all the others). This fully
implement individual alignment;</li> implement individual alignment;</li>
<li>Added similarity matrix printer (-DprintMatrix=1)</li> <li>Added similarity matrix printer (-DprintMatrix=1)</li>
<li>Added Hamming, N-gramms, Needleman-Wunch distance, Jaro and Jaro-Winckler measures on strings</li> <li>Added Hamming, N-gramms, Needleman-Wunch distance, Jaro and
<li>Added -r option for changing reference name in GroupEval</li>
<li>Corrected bug in SymMeanEvaluator</li> <li>Corrected bug in SymMeanEvaluator</li>
<li>Corrected cut behavior (did not cut the last item, best did not work)</li> <li>Corrected cut behavior (did not cut the last item, best did not work)</li>
<li>GenPlot generates directly gnuplot output and LaTeX/PGF inclusion.</li> <li>GenPlot generates directly gnuplot output and LaTeX/PGF inclusion.</li>
