Commit 4ef191af authored by Jérôme Euzenat's avatar Jérôme Euzenat
- for 1.3 indicated distance reengineering
parent c9006156
......@@ -39,9 +39,10 @@
<li>Added three replicas of align(A,p) -> align(), align(A) and align(p)</li>
<li>Added SEKTMapping renderer</li>
<li>Added method and semantics tags to format</li>
<li>Added -p parameter for reading parameter file on must util classes</li>
<li>Added -p parameter for reading parameter file on most util classes</li>
<li>Added alignment method name output in the output format</li>
<li>Implemented GroupAlign allowing to batch-align several ontologies</li>
<li>Started reengineering matrix-based distance alignments</li>
</ul>
<h2>November 23th, 2004</h2>
