GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
4a41edc1
4a41edc1
15 years ago
Jérôme Euzenat
Downloads
Patches
- improved/implemented -D argument
4e230bd9
2
2 changed files
src/fr/inrialpes/exmo/align/util/GenPlot.java
+16
-3
16 additions, 3 deletions
src/fr/inrialpes/exmo/align/util/Procalign.java
+4
-5
4 additions, 5 deletions
20 additions
8 deletions
16
3
4a41edc1
@@ -95,7 +95,7 @@ import fr.inrialpes.exmo.align.parser.AlignmentParser;
public
class
GenPlot
int
STEP
10
Properties
params
n
ull
Properties
params
n
ew
Properties
Vector
String
listAlgo
Vector
GraphEvaluator
listEvaluators
String
fileNames
@@ -125,8 +125,9 @@ public class GenPlot {
longopts
6
new
LongOpt
"grapher"
LongOpt
REQUIRED_ARGUMENT
null
'g'
longopts
7
new
LongOpt
"list"
LongOpt
REQUIRED_ARGUMENT
null
'l'
longopts
8
new
LongOpt
"step"
LongOpt
REQUIRED_ARGUMENT
null
's'
longopts
9
new
LongOpt
"D"
LongOpt
REQUIRED_ARGUMENT
null
'D'
Getopt
g
new
Getopt
args
"ho:d::l:e:g:s:t:"
longopts
Getopt
g
new
Getopt
args
"ho:d::l:
D:
e:g:s:t:"
longopts
int
step
10
int
c
String
arg
@@ -172,6 +173,19 @@ public class GenPlot {
if
arg
null
debug
Integer
parseInt
arg
trim
else
debug
4
break
case
'D'
/* Parameter definition */
arg
g
getOptarg
int
index
arg
indexOf
if
index
params
setProperty
arg
substring
index
arg
substring
index
else
System
err
println
"Bad parameter syntax: "
g
usage
System
exit
break
@@ -188,7 +202,6 @@ public class GenPlot {
listAlgo
add
s
params
new
Properties
if
debug
params
setProperty
"debug"
Integer
toString
debug
// Collect correspondences from alignments in all directories
This diff is collapsed.
4
5
4a41edc1
@@ -178,13 +178,12 @@ public class Procalign {
arg
g
getOptarg
int
index
arg
indexOf
if
index
params
setP
arameter
arg
substring
index
params
setP
roperty
arg
substring
index
arg
substring
index
else
System
err
println
g
usage
System
exit
break
@@ -193,9 +192,9 @@ public class Procalign {
int
i
g
getOptind
if
debug
params
setP
arameter
"debug"
Integer
toString
debug
else
if
params
getP
arameter
"debug"
null
debug
Integer
parseInt
params
getP
arameter
"debug"
params
setP
roperty
"debug"
Integer
toString
debug
else
if
params
getP
roperty
"debug"
null
debug
Integer
parseInt
params
getP
roperty
"debug"
try
Loading
Save comment
