GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
45e3ff33
45e3ff33
14 years ago
Jérôme Euzenat
Downloads
Patches
- The base class for having all rendrerers indented
1371b59e
src/fr/inrialpes/exmo/align/impl/renderer/IndentedRendererVisitor.java
+111
111 additions, 0 deletions
...pes/exmo/align/impl/renderer/IndentedRendererVisitor.java
111 additions
111
45e3ff33
* $Id$
* Copyright (C) INRIA, 2010
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation; either version 2.1 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
package
fr.inrialpes.exmo.align.impl.renderer
import
java.util.Enumeration
import
java.util.Hashtable
import
java.util.Set
import
java.util.HashSet
import
java.util.Properties
import
java.io.PrintWriter
import
java.net.URI
* Structure for indented rendering
* @author Jérôme Euzenat
* @version $Id$
public
class
PrintWriter
writer
null
protected
String
INDENT
protected
String
NL
/** String for the pretty linebreak. **/
protected
String
linePrefix
private
int
prefixCount
public
PrintWriter
writer
NL
System
getProperty
"line.separator"
this
writer
writer
public
void
setIndentString
String
ind
INDENT
ind
public
void
setNewLineString
String
nl
NL
nl
// pretty printing management
// JE: I THINK THAT THIS IS CONVENIENT BUT INDUCES A SERIOUS LAG IN
// PERFORMANCES (BOTH VERSIONS v1 and v2)
// LET SEE IF THERE IS NO WAY TO DO THIS DIRECTLY IN THE WRITER !!!
* Increases the lineprefix by one INDENT
protected
void
increaseIndent
prefixCount
* Decreases the lineprefix by one INDENT
protected
void
decreaseIndent
if
prefixCount
prefixCount
// JE: I would like to see benchmarks showing that this is more efficient
// than adding them to buffer directly each time
private
void
calcPrefix
StringBuilder
buffer
new
StringBuilder
buffer
append
NL
for
int
i
i
prefixCount
i
buffer
append
INDENT
linePrefix
buffer
toString
protected
void
indentedOutputln
String
s
for
int
i
i
prefixCount
i
writer
print
INDENT
writer
print
s
NL
protected
void
indentedOutput
String
s
for
int
i
i
prefixCount
i
writer
print
INDENT
writer
print
s
protected
void
indentedOutputln
for
int
i
i
prefixCount
i
writer
print
INDENT
protected
void
indentedOutput
for
int
i
i
prefixCount
i
writer
print
INDENT
This diff is collapsed.
Loading
Save comment
