Commit 4510c039 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- improved help command
parent 5644701c
......@@ -450,13 +450,17 @@ public class ExtGroupEval {
public void usage() {
System.out.println("usage: ExtGroupEval [options]");
System.out.println("options are:");
System.out.println("\t--format=sepr -r sepr\tSpecifies the extended measures used (symetric/effort-based/precision-oriented/recall-oriented)");
System.out.println("\t--format=sepr -f sepr\tSpecifies the extended measures used (symetric/effort-based/precision-oriented/recall-oriented)");
System.out.println("\t--reference=filename -r filename\tSpecifies the name of the reference alignment file (default: refalign.rdf)");
System.out.println("\t--dominant=algo -s algo\tSpecifies if dominant columns are algorithms or measure");
System.out.println("\t--output=filename -o filename\tSpecifies a file to which the output will go");
// Apparently not implemented
//System.out.println("\t--dominant=algo -s algo\tSpecifies if dominant columns are algorithms or measure");
System.out.println("\t--type=html|xml|tex|ascii -t html|xml|tex|ascii\tSpecifies the output format");
System.out.println("\t--list=algo1,...,algon -l algo1,...,algon\tSequence of the filenames to consider");
System.out.println("\t--color=color -c color\tSpecifies if the output must color even lines of the output");
System.out.println("\t--debug[=n] -d [n]\t\tReport debug info at level n");
System.out.println("\t--help -h\t\t\tPrint this message");
System.err.print("\n"+ExtGroupEval.class.getPackage().getImplementationTitle()+" "+ExtGroupEval.class.getPackage().getImplementationVersion());
System.err.println(" ($Id$)\n");
......@@ -160,10 +160,10 @@ public class GenPlot {
/* List of filename */
fileNames = g.getOptarg();
break;
case 's' :
//case 's' :
/* Step */
break;
//fileNames = g.getOptarg();
//break;
case 'd' :
/* Debug level */
arg = g.getOptarg();
......@@ -569,7 +569,7 @@ which the program does...
System.out.println("usage: WGroupEval [options]");
System.out.println("\t--format=prfot -r prfot\tSpecifies the output order (precision/recall/f-measure/overall/time)");
System.out.println("\t--format=prfot -f prfot\tSpecifies the output order (precision/recall/f-measure/overall/time)");
//System.out.println("\t--sup=algo -s algo\tSpecifies if dominant columns are algorithms or measure");
