Commit 44b2b5a0 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- added namespaces and indentation
parent 38498f3d
...@@ -41,11 +41,28 @@ java AlignmentClient list renderers -> XML ...@@ -41,11 +41,28 @@ java AlignmentClient list renderers -> XML
java AlignmentClient list services -> XML java AlignmentClient list services -> XML
USE USE WITH THE ALIGNMENT SERVER
$ javac -cp .:../../lib/procalign.jar AlignmentClient.java $ javac -cp .:../../lib/procalign.jar AlignmentClient.java
$ java -cp .:../../lib/procalign.jar AlignmentClient match file:///Java/alignapi/html/tutorial/myOnto.owl file:///Java/alignapi/html/tutorial/myOnto.owl $ java -cp .:../../lib/procalign.jar AlignmentClient match align http://alignapi.gforge.inria.fr/tutorial/myOnto.owl http://alignapi.gforge.inria.fr/tutorial/edu.mit.visus.bibtex.owl
<SOAP-ENV:Envelope xmlns:SOAP-ENV='http://schemas.xmlsoap.org/soap/envelope/' xmlns:xsi='http://www.w3.org/1999/XMLSchema-instance' xmlns:xsd='http://www.w3.org/1999/XMLSchema'> <SOAP-ENV:Body><matchResponse><id>0</id><in-reply-to>fr.inrialpes.exmo.align.service.Message@e6233</in-reply-to><alid>http://localhost:8089/alid/1187793046984/21</alid></matchResponse> </SOAP-ENV:Body></SOAP-ENV:Envelope> <SOAP-ENV:Envelope
xmlns='http://exmo.inrialpes.fr/align/service'
xml:base='http://exmo.inrialpes.fr/align/service'
<SOAP-ENV:Body>
<matchResponse>
<id>12</id>
<in-reply-to>fr.inrialpes.exmo.align.service.Message@1fa5d1a</in-reply-to>
<alid>http://aserv.inrialpes.fr:8089/alid/1219842718179/172</alid>
</matchResponse>
</SOAP-ENV:Body>
USE WITH A PARTICULAR ALIGNMENT SERVICE
$ java -cp .:../../lib/procalign.jar AlignmentClient -S http://aserv.inrialpes.fr/aserv align http://alignapi.gforge.inria.fr/tutorial/myOnto.owl http://alignapi.gforge.inria.fr/tutorial/edu.mit.visus.bibtex.owl
