GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
42ca7579
42ca7579
14 years ago
Jérôme Euzenat
Downloads
Patches
- Fully implemented as HeavyLoadedOntology
ae36cffe
Branches containing commit
Tags containing commit
src/fr/inrialpes/exmo/ontowrap/skosapi/SKOSThesaurus.java
+33
-26
33 additions, 26 deletions
33 additions
26 deletions
33
26
42ca7579
@@ -34,6 +34,9 @@ import org.semanticweb.skos.SKOSConcept;
import
org.semanticweb.skos.SKOSLiteral
import
org.semanticweb.skos.SKOSUntypedLiteral
import
org.semanticweb.skos.SKOSDataProperty
import
org.semanticweb.skos.SKOSObjectRelationAssertion
import
org.semanticweb.skos.properties
SKOSNarrowerProperty
import
SKOSBroaderProperty
import
fr.inrialpes.exmo.ontowrap.BasicOntology
import
fr.inrialpes.exmo.ontowrap.HeavyLoadedOntology
@@ -58,6 +61,13 @@ public class SKOSThesaurus extends BasicOntology<SKOSDataset> implements HeavyLo
* can be interpreted in many ways. Hence a SKOS terminology is an OWL Full
* ontology (the S is for Simple).
* Translation from SKOS to OWL (by Antoine Isaac):
* skos:Concept --> owl:Class
* skos:broader --> rdfs:subClassOf
* skos:prefLabel, skos:altLabel, skos:hiddenLabel --> rdfs:label
* skos:notes, skos:definition, skos:scopeNote --> rdfs:comments
* skos:related --> rdfs:seeAlso [ignored]
* OK So what is in the SKOS Data model, since this is the only one that we
* will take into account...
* [SPEC: ]: 12/07/2009
@@ -66,6 +76,8 @@ public class SKOSThesaurus extends BasicOntology<SKOSDataset> implements HeavyLo
* Annotation properties: skos:hiddenLabel, skos:prefLabel, skos:altLabel
* skos:note, skos:changeNote, skos:definition, skos:editorialNote, skos:example, skos:historyNote and skos:scopeNote
* Other object relations: skos:mappingRelation, skos:closeMatch, skos:exactMatch, skos:broadMatch, skos:narrowMatch and skos:relatedMatch
@@ -101,7 +113,6 @@ lang = untypedLiteral.getLang();
We should document:
name < names
annotations
comments(lang) < comments
@@ -122,6 +133,7 @@ lang = untypedLiteral.getLang();
else
return
getFragmentAsLabel
getEntityURI
o
// NEARLY DONE
* returns one of the prefLabel property values for a given SKOS concept in a given language.
* @param o the entity
@@ -137,9 +149,8 @@ lang = untypedLiteral.getLang();
else
return
getEntityName
o
// DONE
* Returns the values of the prefLabel and altLabel properties in a given language.
, hiddenLabel
* @param lang the code of the language ("en", "fr", "es", etc.)
* @return the set of labels
@@ -154,12 +165,11 @@ lang = untypedLiteral.getLang();
* Returns the values of the prefLabel and altLabel properties.
, hiddenLabel
* @param o the concept
* @throws OntowrapException
// DONE
public
Set
String
getEntityNames
Object
o
throws
OntowrapException
Set
String
result
new
HashSet
String
getDataValues
SKOSConcept
o
factory
getSKOSPrefLabelProperty
result
@@ -201,7 +211,6 @@ lang = untypedLiteral.getLang();
return
getEntityComments
o
null
// DONE
* Returns all the values of the "owl:AnnotationProperty" property for a given entity.
* These annotations are those predefined in owl (owl:versionInfo, rdfs:label, rdfs:comment, rdfs:seeAlso and rdfs:isDefinedBy)
@@ -227,7 +236,6 @@ lang = untypedLiteral.getLang();
return
annots
// DONE
* There is no languages on annotations in SKOS API
* Hence we return all of them
@@ -236,7 +244,6 @@ lang = untypedLiteral.getLang();
return
getEntityAnnotations
o
// DONE
public
Object
getEntity
URI
u
throws
OntowrapException
return
factory
getSKOSConcept
u
@@ -249,35 +256,26 @@ lang = untypedLiteral.getLang();
/* all done here */
//@SuppressWarnings("unchecked")
public
Set
getClasses
return
onto
getSKOSConcepts
public
Set
getDataProperties
return
NullSet
// return null; // null or new HashSet()
public
Set
getEntities
return
getClasses
public
Set
getIndividuals
return
NullSet
public
Set
getObjectProperties
return
NullSet
public
Set
getProperties
return
NullSet
@@ -334,10 +332,6 @@ lang = untypedLiteral.getLang();
/** THESE ARE HEAVY LOADED PRIMITIVES
o.getSKOSBroaderConcepts( onto )
o.getSKOSBroaderTransitiveConcepts( onto )
o.getSKOSNarrowerConcepts( onto )
o.getSKOSNarrowerTransitiveConcepts( onto )
/* Capability methods */
// TODO
@@ -346,13 +340,27 @@ lang = untypedLiteral.getLang();
/* Class methods */
// TOIMPROVE: This is really terrible (JE)
public
Set
Object
getSubClasses
Object
c
int
local
int
asserted
int
named
// TODO
return
NullSet
//c.getSKOSNarrowerTransitiveConcepts( onto )
//return ((SKOSConcept)c).getSKOSNarrowerConcepts( onto );
Set
Object
result
new
HashSet
Object
for
trp
SKOSConcept
c
getObjectRelationAssertions
onto
if
trp
getSKOSProperty
instanceof
trp
getSKOSObject
instanceof
SKOSConcept
result
add
trp
getSKOSObject
return
result
// TOIMPROVE
public
Set
Object
getSuperClasses
Object
c
int
local
int
asserted
int
named
// TODO
return
NullSet
//o.getSKOSBroaderTransitiveConcepts( onto )
//return ((SKOSConcept)c).getSKOSBroaderConcepts( onto );
Set
Object
result
new
HashSet
Object
for
trp
SKOSConcept
c
onto
if
trp
getSKOSProperty
instanceof
SKOSBroaderProperty
trp
getSKOSObject
instanceof
SKOSConcept
result
add
trp
getSKOSObject
return
result
public
Set
Object
getProperties
Object
c
int
local
int
asserted
int
named
return
NullSet
@@ -384,7 +392,6 @@ lang = untypedLiteral.getLang();
/* Individual methods */
public
Set
Object
getClasses
Object
i
int
local
int
asserted
int
named
return
NullSet
//return onto.getSKOSConcepts();
This diff is collapsed.
Loading
Save comment
