Commit 3207e986 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- Reimplented SAXParser.parse( uri ) to cover content negotiation
parent 8d50525f
......@@ -116,6 +116,11 @@ The utility may be invoked in the following way:
<div class="terminal">
$ java -cp lib/procalign.jar fr.inrialpes.exmo.align.cli.ParserPrinter file:examples/rdf/newsample.rdf -r fr.inrialpes.exmo.align.impl.renderer.OWLAxiomsRendererVisitor
</div>
It should work with files and with URIs, dereferenceable or not:
$ java -cp lib/procalign.jar fr.inrialpes.exmo.align.cli.ParserPrinter http://alignapi.gforge.inria.fr//tutorial/refalign.rdf
$ java -cp lib/procalign.jar fr.inrialpes.exmo.align.cli.ParserPrinter http://aserv.inrialpes.fr/alid/1317289904908/444
</div>
</p>
<h3>Translating queries</h3>
......@@ -133,7 +133,7 @@ public class ParserPrinter extends CommonCLI {
System.exit(-1);
//logger.trace("Filename: {}", initName);
try {
// Create parser
......@@ -39,6 +39,8 @@ import java.io.InputStream;
import java.io.File;
import java.net.URI;
import java.net.URISyntaxException;
import java.net.URL;
import java.net.URLConnection;
import java.lang.Integer;
import java.lang.Double;
import java.util.Hashtable;
......@@ -198,10 +200,16 @@ public class XMLParser extends DefaultHandler {
* If the current process has links (import or include) to others documents then they are
* parsed.
* @param uri URI of the document to parse
* Note: SAXParser has a parse( String uri ) method but it does not do content negotiation
* Hence we have to reimplement it (2014)
public Alignment parse( String uri ) throws AlignmentException {
try {
parser.parse( uri, this );
// Reimplemented URI parsing because this does not do content negotiation
//parser.parse( uri, this );
URLConnection connection = new URL( uri ).openConnection();
connection.setRequestProperty( "Accept", "text/xml, application/rdf+xml" );
parser.parse( connection.getInputStream(), this );
} catch ( SAXException sex ) {
throw new AlignmentException( "Parsing error", sex );
} catch ( IOException ioex ) {
