Commit 27de74d3 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- small syntax twist due to Francois comments
parent 60720096
......@@ -78,8 +78,8 @@
<edoal:Class>
<edoal:and rdf:parseType="Collection">
<edoal:Class rdf:about="&vin;Vin"/>
<edoal:PropertyValueRestriction>
<edoal:onProperty>
<edoal:AttributeValueRestriction>
<edoal:onAttribute>
<edoal:Relation>
<edoal:compose rdf:parseType="Collection">
<edoal:Relation rdf:about="&vin;hasTerroir"/>
......@@ -90,7 +90,7 @@
<edoal:comparator rdf:resource="&xsd;equals"/>
<!--edoal:value>loc:Aquitaine</edoal:value-->
<edoal:value><edoal:Instance rdf:about="&vin;Aquitaine"/></edoal:value>
</edoal:PropertyValueRestriction>
</edoal:AttributeValueRestriction>
</edoal:and>
</edoal:Class>
</entity2>
......@@ -83,14 +83,14 @@ public enum SyntaxElement {
TIME( Namespace.ALIGNMENT, "time"),
TYPE( Namespace.ALIGNMENT, "type"),
URI( Namespace.ALIGNMENT, "uri"),
XML( Namespace.ALIGNMENT, "xml"),
ONTOLOGY( Namespace.ALIGNMENT, "Ontology", true ),
LOCATION( Namespace.ALIGNMENT, "location"),
// EDOAL NAMESPACE
AND( Namespace.EDOAL, "and", Constructor.AND),
APPLY( Namespace.EDOAL, "Apply", true),
ARGUMENTS( Namespace.EDOAL, "arguments"),
//ARGUMENTS( Namespace.EDOAL, "arguments"),
ATTR_TRANSF( Namespace.EDOAL, "transf"),
CLASS_EXPR( Namespace.EDOAL, "Class", true),//ALIGNMENT
CODOMAIN_RESTRICTION(Namespace.EDOAL, "CodomainRestriction", true),
......@@ -98,33 +98,35 @@ public enum SyntaxElement {
COMPOSE( Namespace.EDOAL, "compose", Constructor.COMP),
DATATYPE( Namespace.EDOAL, "datatype"),
DOMAIN_RESTRICTION(Namespace.EDOAL, "DomainRestriction", true),
FIRST( Namespace.EDOAL, "first"),
ID( Namespace.EDOAL, "Id", true), // Useless
//FIRST( Namespace.EDOAL, "first"),
//ID( Namespace.EDOAL, "Id", true), // Useless
INSTANCE_EXPR( Namespace.EDOAL, "Instance", true),
INVERSE( Namespace.EDOAL, "inverse", Constructor.INVERSE),
NEXT( Namespace.EDOAL, "next"),
//NEXT( Namespace.EDOAL, "next"),
NOT( Namespace.EDOAL, "not", Constructor.NOT),
ONPROPERTY( Namespace.EDOAL, "onProperty"),
ONPROPERTY( Namespace.EDOAL, "onAttribute"),
OR( Namespace.EDOAL, "or", Constructor.OR),
PARAMETERS( Namespace.EDOAL, "parameters"),
PATH( Namespace.EDOAL, "Path", true),
PROPERTIES( Namespace.EDOAL, "properties"),
//PARAMETERS( Namespace.EDOAL, "parameters"),
//PATH( Namespace.EDOAL, "Path", true),
//PROPERTIES( Namespace.EDOAL, "properties"),
PROPERTY( Namespace.EDOAL, "Property", true),
PROPERTY_EXPR( Namespace.EDOAL, "Property"), // ??
PROPERTY_OCCURENCE_COND(Namespace.EDOAL, "PropertyOccurenceRestriction", true),
PROPERTY_OCCURENCE_COND(Namespace.EDOAL, "AttributeOccurenceRestriction", true),
PROPERTY_TYPE_COND(Namespace.EDOAL, "PropertyTypeRestriction", true),
PROPERTY_VALUE_COND(Namespace.EDOAL, "PropertyValueRestriction", true),
RELATION_DOMAIN_COND(Namespace.EDOAL, "RelationDomainRestriction", true),
PROPERTY_VALUE_COND(Namespace.EDOAL, "AttributeValueRestriction", true),
REFLEXIVE( Namespace.EDOAL, "reflexive", Constructor.REFLEXIVE),
RELATION_EXPR( Namespace.EDOAL, "Relation", true),
//RESTRICTION(Namespace.EDOAL, "Restriction"),
SERVICE( Namespace.EDOAL, "service"),
//SERVICE( Namespace.EDOAL, "service"),
SYMMETRIC( Namespace.EDOAL, "symmetric", Constructor.SYMMETRIC),
TOCLASS( Namespace.EDOAL, "toClass"),
TOCLASS( Namespace.EDOAL, "class"),
TRANSITIVE( Namespace.EDOAL, "transitive", Constructor.TRANSITIVE),
TYPE_COND( Namespace.EDOAL, "TypeRestriction", true),
VALUE( Namespace.EDOAL, "value"),
VALUE_COND( Namespace.EDOAL, "ValueRestriction", true)
VAR( Namespace.EDOAL, "var"),
VALUE_COND( Namespace.EDOAL, "ValueRestriction", true),
/** Operator to determine how to combine the expressions */
