Commit 24e7af64 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- reintroduced the constructor without arguments (used in neontk)
parent 96adb2c1
* $Id$
* Copyright (C) INRIA, 2008-2010, 2012
* Copyright (C) INRIA, 2008-2010, 2012-2013
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
......@@ -27,6 +27,9 @@ import java.util.Map;
import java.util.NoSuchElementException;
import java.util.Set;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import org.semanticweb.owlapi.apibinding.OWLManager;
import org.semanticweb.owlapi.model.IRI;
import org.semanticweb.owlapi.model.OWLAnnotation;
......@@ -61,10 +64,15 @@ import fr.inrialpes.exmo.ontowrap.OntowrapException;
import fr.inrialpes.exmo.ontowrap.util.EntityFilter;
public class OWLAPI3Ontology extends BasicOntology<OWLOntology> implements HeavyLoadedOntology<OWLOntology> {
final static Logger logger = LoggerFactory.getLogger( OWLAPI3Ontology.class );
private boolean onlyLocalEntities=true;
public OWLAPI3Ontology(boolean onlyLocalEntities) {
this.onlyLocalEntities=onlyLocalEntities;
private boolean onlyLocalEntities = true;
// default is true
public OWLAPI3Ontology() {}
public OWLAPI3Ontology( boolean onlyLocalEntities ) {
this.onlyLocalEntities = onlyLocalEntities;
private <K> Set<K> getFilteredOrNot(Set<K> s) {
......@@ -128,10 +136,10 @@ public class OWLAPI3Ontology extends BasicOntology<OWLOntology> implements Heavy
else if (c instanceof IRI) {
//System.out.println(c.getClass()+ " : "+c);
// logger.trace( "{} : {}", c.getClass(), c );
IRI i = (IRI) c;
OWLAnnotationProperty ann = OWLManager.getOWLDataFactory().getOWLAnnotationProperty(i);
System.out.println(ann);
logger.trace( ann.toString() );
return annotations;
......@@ -238,7 +246,7 @@ public class OWLAPI3Ontology extends BasicOntology<OWLOntology> implements Heavy
public Set<? extends Object> getObjectProperties() {
//System.err.println ( "ONTO: "+onto );
// logger.trace( "ONTO: {}", onto );
//return onto.getObjectPropertiesInSignature();
return getFilteredOrNot(onto.getObjectPropertiesInSignature());
