Commit 249eff12 authored by Jérôme David's avatar Jérôme David
Add javadoc for annotation getters.
parent c963ea26
* $Id$ * $Id$
* Copyright (C) INRIA Rhne-Alpes, 2008 * Copyright (C) INRIA Rh�ne-Alpes, 2008
* This program is free software; you can redistribute it and/or modify * This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by * it under the terms of the GNU Lesser General Public License as published by
...@@ -30,12 +30,56 @@ public interface LoadedOntology<O> extends Ontology<O> { ...@@ -30,12 +30,56 @@ public interface LoadedOntology<O> extends Ontology<O> {
public Object getEntity( URI u ) throws AlignmentException; public Object getEntity( URI u ) throws AlignmentException;
public URI getEntityURI( Object o ) throws AlignmentException; public URI getEntityURI( Object o ) throws AlignmentException;
* return one of the "rdfs:label" property values for a given entity.
* @param o the entity
* @return a label
* @throws AlignmentException
public String getEntityName( Object o ) throws AlignmentException; public String getEntityName( Object o ) throws AlignmentException;
* Returns the values of the "rdfs:label" property for a given entity and for a given natural language (attribute xml:lang).
* @param lang the code of the language ("en", "fr", "es", etc.)
* @return the set of labels
public Set<String> getEntityNames( Object o , String lang ) throws AlignmentException; public Set<String> getEntityNames( Object o , String lang ) throws AlignmentException;
* Returns all the values of the "rdfs:label" property for a given entity.
public Set<String> getEntityNames( Object o ) throws AlignmentException; public Set<String> getEntityNames( Object o ) throws AlignmentException;
* Returns the values of the "rdfs:comment" property for a given entity and for a given natural language (attribute xml:lang).
* @return the set of comments
public Set<String> getEntityComments( Object o , String lang ) throws AlignmentException; public Set<String> getEntityComments( Object o , String lang ) throws AlignmentException;
* Returns all the values of the "rdfs:comment" property for a given entity
public Set<String> getEntityComments( Object o ) throws AlignmentException; public Set<String> getEntityComments( Object o ) throws AlignmentException;
* Returns all the values of the "owl:AnnotationProperty" property for a given entity.
* These annotations are those predefined in owl (owl:versionInfo, rdfs:label, rdfs:comment, rdfs:seeAlso and rdfs:isDefinedBy)
* but also all other defined annotation properties which are subClass of "owl:AnnotationProperty"
* @return the set of annotation values
public Set<String> getEntityAnnotations( Object o ) throws AlignmentException; public Set<String> getEntityAnnotations( Object o ) throws AlignmentException;
public boolean isEntity( Object o ); public boolean isEntity( Object o );
