Commit 227e5615 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- hidden absent vocabulary classes
parent 0e661a8e
...@@ -62,11 +62,11 @@ The alignment vocabulary has the following features: ...@@ -62,11 +62,11 @@ The alignment vocabulary has the following features:
<p> <p>
In the alignment format, an alignment is a set of cells, each cell being a correspondence between two entities. The alignment vocabulary extend this scheme by allowing cells to contain compound entity descriptions. Each entity can be typed according to one of the following category: Class, Instance, Relation, Property. A relation corresponds to an object property in OWL, a property to a datatype property. Each entity can then be restricted, and transformation can be specified on propery values. In the alignment format, an alignment is a set of cells, each cell being a correspondence between two entities. The alignment vocabulary extend this scheme by allowing cells to contain compound entity descriptions. Each entity can be typed according to one of the following category: Class, Instance, Relation, Property. A relation corresponds to an object property in OWL, a property to a datatype property. Each entity can then be restricted, and transformation can be specified on propery values.
</p> </p>
<p> <!--p>
The diagram below shows the vocabulary classes ??? The diagram below shows the vocabulary classes ???
<img src="img/alignment-vocabulary-classes.png" border="0" alt=""> <img src="img/alignment-vocabulary-classes.png" border="0" alt="">
</p> </p-->
<p> <p>
While <i>Alignment</i> and <i>Cell</i> are described by the <a href="format.html">alignment format</a>, we will focus here on the remaining classes.</p> While <i>Alignment</i> and <i>Cell</i> are described by the <a href="format.html">alignment format</a>, we will focus here on the remaining classes.</p>
