Commit 06ff9c60 authored by Jérôme Pierson's avatar Jérôme Pierson
the jade messageontology folder to the repository
parent 3c28ad34
with 393 additions and 0 deletions
package fr.inrialpes.exmo.align.service.jade.messageontology;
import jade.content.*;
import jade.util.leap.*;
import jade.core.*;
* Protege name: AClient
* @author ontology bean generator
* @version 2007/03/19, 17:12:29
public class AClient extends AID{
import jade.core.*;
* Protege name: ALIGN
public class ALIGN extends Action implements Predicate{
import jade.core.*;
* Protege name: AServer
public class AServer extends AID{
import jade.core.*;
* Protege name: Action
public class Action implements Predicate {
* Protege name: hasParameter
private List hasParameter = new ArrayList();
public void addHasParameter(Parameter elem) {
List oldList = this.hasParameter;
hasParameter.add(elem);
public boolean removeHasParameter(Parameter elem) {
boolean result = hasParameter.remove(elem);
return result;
public void clearAllHasParameter() {
hasParameter.clear();
public Iterator getAllHasParameter() {return hasParameter.iterator(); }
public List getHasParameter() {return hasParameter; }
public void setHasParameter(List l) {hasParameter = l; }
import jade.core.*;
* Protege name: CUT
public class CUT extends Action implements Predicate {
import jade.core.*;
* Protege name: FIND
public class FIND extends Action implements Predicate {
<?xml version="1.0"?>
<rdf:RDF
xmlns:j.0="http://jade.cselt.it/beangenerator#"
xmlns="http://www.inrialpes.fr/exmo/align/service/jade/FIPAJADEOntology.owl#"
xmlns:protege="http://protege.stanford.edu/plugins/owl/protege#"
xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
xmlns:xsd="http://www.w3.org/2001/XMLSchema#"
xmlns:rdfs="http://www.w3.org/2000/01/rdf-schema#"
xmlns:owl="http://www.w3.org/2002/07/owl#"
xml:base="http://www.inrialpes.fr/exmo/align/service/jade/FIPAJADEOntology.owl">
<owl:Ontology rdf:about="">
<owl:imports rdf:resource="http://jade.cselt.it/beangenerator"/>
</owl:Ontology>
<owl:ObjectProperty rdf:ID="hasParameter">
<rdfs:domain>
<j.0:JADE-CLASS rdf:ID="Action">
<rdfs:subClassOf rdf:resource="http://jade.cselt.it/beangenerator#Predicate"/>
</j.0:JADE-CLASS>
</rdfs:domain>
<rdfs:range>
<j.0:JADE-CLASS rdf:ID="Parameter">
<rdfs:subClassOf rdf:resource="http://jade.cselt.it/beangenerator#Concept"/>
</j.0:JADE-CLASS>
</rdfs:range>
</owl:ObjectProperty>
<owl:FunctionalProperty rdf:ID="name">
<rdf:type rdf:resource="http://www.w3.org/2002/07/owl#DatatypeProperty"/>
<rdfs:range rdf:resource="http://www.w3.org/2001/XMLSchema#string"/>
<rdfs:domain rdf:resource="#Parameter"/>
</owl:FunctionalProperty>
<owl:FunctionalProperty rdf:ID="value">
<j.0:JADE-CLASS rdf:ID="FIND">
<rdfs:subClassOf rdf:resource="#Action"/>
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="AClient">
<rdfs:subClassOf rdf:resource="http://jade.cselt.it/beangenerator#AID"/>
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="CUT">
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="STORE">
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="TRANSLATE">
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="ALIGN">
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="METADATA">
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="RETRIEVE">
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="AServer">
</j.0:JADE-CLASS>
<j.0:JADE-CLASS rdf:ID="LOAD">
</j.0:JADE-CLASS>
</rdf:RDF>
<!-- Created with Protege (with OWL Plugin 3.2.1, Build 365) http://protege.stanford.edu -->
// file: JADEFIPAAlignmentServerOntologyOntology.java generated by ontology bean generator. DO NOT EDIT, UNLESS YOU ARE REALLY SURE WHAT YOU ARE DOING!
import jade.content.onto.*;
import jade.content.schema.*;
import jade.util.leap.HashMap;
import jade.content.lang.Codec;
import jade.core.CaseInsensitiveString;
/** file: JADEFIPAAlignmentServerOntologyOntology.java
public class JADEFIPAAlignmentServerOntology extends jade.content.onto.Ontology {
//NAME
public static final String ONTOLOGY_NAME = "JADEFIPAAlignmentServerOntology";
// The singleton instance of this ontology
private static ReflectiveIntrospector introspect = new ReflectiveIntrospector();
private static Ontology theInstance = new JADEFIPAAlignmentServerOntology();
public static Ontology getInstance() {
return theInstance;
// VOCABULARY
public static final String METADATA="METADATA";
public static final String FIND="FIND";
public static final String TRANSLATE="TRANSLATE";
public static final String ACTION_HASPARAMETER="hasParameter";
public static final String ACTION="Action";
public static final String CUT="CUT";
public static final String LOAD="LOAD";
public static final String RETRIEVE="RETRIEVE";
public static final String ALIGN="ALIGN";
public static final String STORE="STORE";
public static final String ACLIENT="AClient";
public static final String ASERVER="AServer";
public static final String _NAME="name";
public static final String _VALUE="value";
public static final String parameter="parameter";
* Constructor
private JADEFIPAAlignmentServerOntology(){
super(ONTOLOGY_NAME, BasicOntology.getInstance());
try {
// adding Concept(s)
ConceptSchema Schema = new ConceptSchema(parameter);
add(Schema, fr.inrialpes.exmo.align.service.jade.messageontology.Parameter.class);
// adding AgentAction(s)
// adding AID(s)
ConceptSchema aServerSchema = new ConceptSchema(ASERVER);
add(aServerSchema, fr.inrialpes.exmo.align.service.jade.messageontology.AServer.class);
ConceptSchema aClientSchema = new ConceptSchema(ACLIENT);
add(aClientSchema, fr.inrialpes.exmo.align.service.jade.messageontology.AClient.class);
// adding Predicate(s)
PredicateSchema storeSchema = new PredicateSchema(STORE);
add(storeSchema, fr.inrialpes.exmo.align.service.jade.messageontology.STORE.class);
PredicateSchema alignSchema = new PredicateSchema(ALIGN);
add(alignSchema, fr.inrialpes.exmo.align.service.jade.messageontology.ALIGN.class);
PredicateSchema retrieveSchema = new PredicateSchema(RETRIEVE);
add(retrieveSchema, fr.inrialpes.exmo.align.service.jade.messageontology.RETRIEVE.class);
PredicateSchema loadSchema = new PredicateSchema(LOAD);
add(loadSchema, fr.inrialpes.exmo.align.service.jade.messageontology.LOAD.class);
PredicateSchema cutSchema = new PredicateSchema(CUT);
add(cutSchema, fr.inrialpes.exmo.align.service.jade.messageontology.CUT.class);
PredicateSchema actionSchema = new PredicateSchema(ACTION);
add(actionSchema, fr.inrialpes.exmo.align.service.jade.messageontology.Action.class);
PredicateSchema translateSchema = new PredicateSchema(TRANSLATE);
add(translateSchema, fr.inrialpes.exmo.align.service.jade.messageontology.TRANSLATE.class);
PredicateSchema findSchema = new PredicateSchema(FIND);
add(findSchema, fr.inrialpes.exmo.align.service.jade.messageontology.FIND.class);
PredicateSchema metadataSchema = new PredicateSchema(METADATA);
add(metadataSchema, fr.inrialpes.exmo.align.service.jade.messageontology.METADATA.class);
// adding fields
Schema.add(_VALUE, (TermSchema)getSchema(BasicOntology.STRING), ObjectSchema.OPTIONAL);
Schema.add(_NAME, (TermSchema)getSchema(BasicOntology.STRING), ObjectSchema.OPTIONAL);
actionSchema.add(ACTION_HASPARAMETER, Schema, 0, ObjectSchema.UNLIMITED);
// adding name mappings
// adding inheritance
storeSchema.addSuperSchema(actionSchema);
cutSchema.addSuperSchema(actionSchema);
findSchema.addSuperSchema(actionSchema);
loadSchema.addSuperSchema(actionSchema);
alignSchema.addSuperSchema(actionSchema);
retrieveSchema.addSuperSchema(actionSchema);
metadataSchema.addSuperSchema(actionSchema);
translateSchema.addSuperSchema(actionSchema);
}catch (java.lang.Exception e) {e.printStackTrace();}
import jade.core.*;
* Protege name: LOAD
public class LOAD extends Action implements Predicate {
import jade.core.*;
* Protege name: METADATA
public class METADATA extends Action implements Predicate {
import jade.core.*;
* Protege name: Paramameter
public class Parameter implements Concept {
* Protege name: value
private String value;
public void setValue(String value) {
this.value=value;
public String getValue() {
return this.value;
* Protege name: name
private String name;
public void setName(String value) {
this.name=value;
public String getName() {
return this.name;
import jade.core.*;
* Protege name: RETRIEVE
public class RETRIEVE extends Action implements Predicate {
import jade.core.*;
* Protege name: STORE
public class STORE extends Action implements Predicate{
import jade.core.*;
* Protege name: TRANSLATE
public class TRANSLATE extends Action implements Predicate {
