GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
06c38e5c
06c38e5c
16 years ago
Jérôme Euzenat
Downloads
Patches
- prepared full implementation of the different evaluations
55e420ac
src/fr/inrialpes/exmo/align/impl/eval/ExtPREvaluator.java
+28
-5
28 additions, 5 deletions
28 additions
5 deletions
28
5
06c38e5c
@@ -123,7 +123,9 @@ public class ExtPREvaluator extends BasicEvaluator {
URI
uri2
onto2
getEntityURI
c2
getObject2
URI
uri2
onto2
getEntityURI
c2
getObject2
// if (c1.getobject2 == c2.getobject2)
if
uri1
toString
equals
uri2
toString
if
uri1
toString
equals
uri2
toString
symsimilarity
symsimilarity
symsimilarity
effsimilarity
orientsimilarity
c1
null
// out of the loop.
c1
null
// out of the loop.
@@ -133,7 +135,10 @@ public class ExtPREvaluator extends BasicEvaluator {
// running the Hungarian method...
Enumeration
e2
align2
getElements
Enumeration
e2
align2
getElements
if
c1
null
if
c1
null
symsimilarity
symsimilarity
computeSymSimilarity
c1
e2
// Add guards
symsimilarity
c1
e2
effsimilarity
computeEffSimilarity
c1
e2
orientsimilarity
computeOrientSimilarity
c1
e2
@@ -179,6 +184,24 @@ public class ExtPREvaluator extends BasicEvaluator {
return
Math
pow
symALPHA
minval
return
Math
pow
symALPHA
minval
* This computes similarity depending on structural measures:
* the similarity is symALPHA^minval, symALPHA being lower than 1.
* minval is the length of the subclass chain.
protected
double
Cell
c1
Enumeration
s2
return
protected
double
Cell
c1
Enumeration
s2
return
protected
int
relativePosition
Object
o1
Object
o2
HeavyLoadedOntology
Object
onto
throws
AlignmentException
protected
int
relativePosition
Object
o1
Object
o2
HeavyLoadedOntology
Object
onto
throws
AlignmentException
if
onto
isClass
o1
onto
isClass
o2
if
onto
isClass
o1
onto
isClass
o2
isSuperClass
o2
o1
onto
// This is the level
isSuperClass
o2
o1
onto
@@ -196,7 +219,7 @@ public class ExtPREvaluator extends BasicEvaluator {
public
boolean
isSuperProperty
Object
prop1
Object
prop2
HeavyLoadedOntology
Object
ontology
throws
AlignmentException
public
boolean
isSuperProperty
Object
prop1
Object
prop2
HeavyLoadedOntology
Object
ontology
throws
AlignmentException
return
ontology
getSuperProperties
prop2
OntologyFactory
ANY
OntologyFactory
ANY
OntologyFactory
ANY
contains
prop1
return
ontology
getSuperProperties
prop2
OntologyFactory
DIRECT
OntologyFactory
ANY
OntologyFactory
ANY
contains
prop1
@@ -219,7 +242,7 @@ public class ExtPREvaluator extends BasicEvaluator {
public
int
isSuperClass
Object
class1
Object
class2
HeavyLoadedOntology
Object
ontology
throws
AlignmentException
public
int
isSuperClass
Object
class1
Object
class2
HeavyLoadedOntology
Object
ontology
throws
AlignmentException
URI
uri1
ontology
getEntityURI
class1
URI
uri1
ontology
getEntityURI
class1
Set
Object
bufferedSuperClasses
null
Set
Object
null
Set
Object
superclasses
ontology
getSuperClasses
class1
OntologyFactory
ANY
OntologyFactory
ANY
OntologyFactory
ANY
Set
Object
superclasses
ontology
getSuperClasses
class1
OntologyFactory
DIRECT
OntologyFactory
ANY
OntologyFactory
ANY
int
level
int
level
while
superclasses
isEmpty
while
superclasses
isEmpty
@@ -233,7 +256,7 @@ public class ExtPREvaluator extends BasicEvaluator {
if
uri1
toString
equals
uri2
toString
if
uri1
toString
equals
uri2
toString
return
level
return
level
else
else
superclasses
addAll
ontology
getSuperClasses
entity
OntologyFactory
ANY
OntologyFactory
ANY
OntologyFactory
ANY
superclasses
addAll
ontology
getSuperClasses
entity
OntologyFactory
DIRECT
OntologyFactory
ANY
OntologyFactory
ANY
This diff is collapsed.
Loading
Save comment
