Commit 02dd34b0 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- important update
parent e5d54afa
...@@ -19,6 +19,7 @@ ...@@ -19,6 +19,7 @@
<p><ul compact="1"> <p><ul compact="1">
<li>Implement level 2OMWG alignments (version 3);</li> <li>Implement level 2OMWG alignments (version 3);</li>
<li>Completing the reference manual</li> <li>Completing the reference manual</li>
<li>Autogenerate wsdl</li>
</ul></p> </ul></p>
<h2>Current SVN trunk version</h2> <h2>Current SVN trunk version</h2>
...@@ -26,26 +27,32 @@ ...@@ -26,26 +27,32 @@
<!--p><b>Version 3.1: xx/xx/2007 - ??</b></p--> <!--p><b>Version 3.1: xx/xx/2007 - ??</b></p-->
<li>Added Web Service Alignment server profile</li> <li>Added more ontology information in format, changed the
<li>Added a <tt>parseString( String )</tt> method in <tt>AlignmentParser</tt></li> implementation of ontology descriptions (format/parser/impl)</li>
<li>Implemented parsing of relations named by class name</li> <li>Added Web Service Alignment server profile (service)</li>
<li>Got rid of the property file for wordnet</li> <li>Added a <tt>parseString( String )</tt> method
<li>In Server/FIPA, suppressed generated files on close()</li> in <tt>AlignmentParser</tt> (parser)</li>
<li>In AlignmentService, suppressed all printouts (Jade or Jetty logging)</li> <li>Implemented parsing of relations named by class name (parser)</li>
<li>In AlignmentService, added file logging option</li> <li>Got rid of the property file for wordnet (ling)</li>
<li>Completely rewritten autodetection of renderers and methods in server</li> <li>In Server/FIPA, suppressed generated files on <tt>close()</tt> (service)</li>
<li>Suppressed all printouts (Jade or Jetty logging) (service)</li>
<li>Added file logging option (service)</li>
<li>Completely rewritten autodetection of renderers and methods in server (service)</li>
<li>Modified interface of embedded methods</li> <li>Modified interface of embedded methods</li>
<li>Added guarantee that results displayed by GroupEval be sorted <li>Added guarantee that results displayed by <tt>GroupEval</tt> be sorted
(thanks Vassilis Spiliopoulos)</li> (thanks Vassilis Spiliopoulos) (util)</li>
<li>Added namespace support in BasicAlignment</li> <li>Added namespace support in BasicAlignment (impl)</li>
<li>Forced trailing slash in HTML menu URLs</li> <li>Forced trailing slash in HTML menu URLs (service)</li>
<li>Used Jetty as an embedded HTTP server</li> <li>Changed for Jetty as an embedded HTTP server (service)</li>
<li>Implemented alignment upload (service)</li>
<li>Corrected an error on "force"-ing alignment in Server/HTML (was <li>Corrected an error on "force"-ing alignment in Server/HTML (was
inverted)</li> inverted) (service)</li>
<li>Corrected a bug concerning extension namespaces</li> <li>Corrected a bug concerning extension namespaces</li>
<li>Corrected bugs in relation writing/parsing</li> <li>Corrected bugs in relation writing/parsing (parser)</li>
<li>Improved web pages (reorganisation)</li> <li>Corrected a bug in <tt>SubsDistanceAlignment</tt> when URI have no
<li>Transferred the TODOs to gforge</li> fragments (method)</li>
<li>Improved web pages (reorganisation) (html)</li>
<li>Transferred the TODOs to gforge (html)</li>
</ul></p> </ul></p>
<h2>February 25th, 2007</h2> <h2>February 25th, 2007</h2>
