Commit d67d80fb authored by autodistries's avatar autodistries
run multiple sniffer.py at once on a single node device
parent 92eb3ba5
1 merge request!1Refactoring, new features
...@@ -62,7 +62,7 @@ ...@@ -62,7 +62,7 @@
- name: Double-check input variables - name: Double-check input variables
assert: assert:
that: "{{ _interfaces|length }} == _channels" that: "{{ _interfaces|length }} == {{ _channels|length }}"
delegate_to: 127.0.0.1 delegate_to: 127.0.0.1
run_once: True run_once: True
...@@ -6,4 +6,4 @@ ...@@ -6,4 +6,4 @@
tasks: tasks:
- name: say things to tty1 - name: say things to tty1
ansible.builtin.shell: echo {{ inventory_hostname }} {{ group_names[1] }} \n| sudo tee /dev/tty1 || /bin/true ansible.builtin.shell: echo {{ inventory_hostname }} {{ group_names[1] }} | sudo tee /dev/tty1 && /bin/true
