Commit 382f4074 authored by IMBERT Matthieu's avatar IMBERT Matthieu
version 2.8.2
parent 40b7bb87
Pipeline #1138902 passed
......@@ -35,7 +35,7 @@ along with Execo. If not, see <http://www.gnu.org/licenses/>
Versions
latest stable version: v2.8.1 (2024-10-21)
latest stable version: v2.8.2 (2025-03-18)
Installation instructions
python-execo (2.8.2) unstable; urgency=medium
* [execo_g5k] planning: fix exclusion of hosts/cluster additional constraint
* [execo_g5k] api_utils: get_cluster_site() returns None for an unknown cluster instead of raising an exception (to be consistent with the rest of the api eg. get_host_cluster()
* [execo, execo_g5k] fix escape sequences (in regexes or in strings)
* [execo, execo_g5k] use pipes.quote or shlex.quote depending on py version
* [doc] fix bug reporting url
* [execo] utils: singleton_to_collection better None handling -> empty list
* [execo_g5k] oar: add -t origin=execo to all jobs
* [execo_g5k] remove oargridsub (but the examples in the user guide still need to be updated)
-- Matthieu Imbert <matthieu.imbert@inria.fr> Tue, 18 Mar 2025 13:09:22 +0100
python-execo (2.8.1) unstable; urgency=medium
* [execo, execo_g5k, execi_engine] fix regexes thanks to python 3.12 improved handling of invalid escape sequences (https://docs.python.org/3/whatsnew/3.12.html#other-language-changes)
......@@ -18,9 +18,9 @@ with packages managed by your distribution package manager.
- Install from a release tar.gz package::
$ wget https://gitlab.inria.fr/mimbert/execo/-/package_files/[...]/download -O execo-2.8.1.tar.gz
$ tar xzf execo-2.8.1.tar.gz
$ cd execo-2.8.1/
$ wget https://gitlab.inria.fr/mimbert/execo/-/package_files/[...]/download -O execo-2.8.2.tar.gz
$ tar xzf execo-2.8.2.tar.gz
$ cd execo-2.8.2/
$ python setup.py install --user
- Or install from source repository if you want the very latest
......@@ -40,7 +40,7 @@ with packages managed by your distribution package manager.
- Or install from debian package::
$ dpkg -i python-execo_2.8.1_all.deb
$ dpkg -i python-execo_2.8.2_all.deb
Configuration
