GitLab
Explore
Primary navigation
Search or go to…
dolfin_warp
Manage
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Operate
Terraform modules
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Martin Genet
dolfin_warp
e8b769c9
e8b769c9
8 years ago
Martin Genet
Downloads
Patches
README.md edited online with Bitbucket
1e3e1312
Branches containing commit
Tags containing commit
README.md
+4
-5
4 additions, 5 deletions
README.md
4 additions
5 deletions
README.md
4
5
e8b769c9
@@ -16,14 +16,13 @@ In `fenics.yaml`, add `numpy` & `scipy` in the list of requested packages, and s
### Installation
### Installation
Get the code:
Get the code:
git clone git@bitbucket.org:mgenet/dolfin_dic.git
To load the library within python, the simplest is to add the folder containing
`dolfin_dic`
to
`PYTHONPATH`
To
be able to
`dolfin_dic`
to
the
`PYTHONPATH`
environment variable
export PYTHONPATH=$PYTHONPATH:/path/to/folder
(To make this permanent, add the line to
`~/.bashrc`
`~/.bashrc`
.) Then you should be able to load the library within python:
Then you can load the library within python:
> import dolfin_dic as ddic
\ No newline at end of file
This diff is collapsed.
Loading
Save comment
