GitLab
Explore
Primary navigation
Search or go to…
dolfin_warp
Manage
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Operate
Terraform modules
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Martin Genet
dolfin_warp
e681a1d1
e681a1d1
6 years ago
Martin Genet
Downloads
Patches
New energy for generated images
6d8ee342
Branches containing commit
Tags containing commit
Energy_GeneratedImage.py
+260
260 additions, 0 deletions
260 additions
260
e681a1d1
#coding=utf8
### Created by Martin Genet, 2016-2018 ###
### École Polytechnique, Palaiseau, France ###
import
dolfin
import
numpy
import
myPythonLibrary
as
mypy
import
myVTKPythonLibrary
as
myvtk
import
dolfin_dic
as
ddic
from
Energy
import
Energy
class
WarpedImageEnergy
Energy
def
__init__
self
problem
image_series
quadrature_degree
name
im
w
1.
ref_frame
dynamic_scaling
False
self
problem
problem
self
printer
self
problem
printer
self
image_series
image_series
self
quadrature_degree
quadrature_degree
self
name
name
self
w
w
self
ref_frame
ref_frame
self
dynamic_scaling
dynamic_scaling
self
printer
print_str
Defining warped image correlation energy…
self
printer
inc
self
printer
print_str
Defining quadrature finite elements…
# fe
self
fe
dolfin
FiniteElement
family
Quadrature
cell
self
problem
mesh
ufl_cell
degree
self
quadrature_degree
quad_scheme
default
self
fe
_quad_scheme
default
# should not be needed
for
sub_element
in
self
fe
sub_elements
sub_element
_quad_scheme
default
# ve
self
ve
dolfin
VectorElement
family
Quadrature
cell
self
problem
mesh
ufl_cell
degree
self
quadrature_degree
quad_scheme
default
self
ve
_quad_scheme
default
for
sub_element
in
self
ve
sub_elements
sub_element
_quad_scheme
default
# te
self
te
dolfin
TensorElement
family
Quadrature
cell
self
problem
mesh
ufl_cell
degree
self
quadrature_degree
quad_scheme
default
self
te
_quad_scheme
default
for
sub_element
in
self
te
sub_elements
sub_element
_quad_scheme
default
self
printer
print_str
Defining measure…
self
form_compiler_parameters
quadrature_degree
self
quadrature_degree
quadrature_scheme
default
self
dV
dolfin
Measure
dx
domain
self
problem
mesh
metadata
self
self
printer
print_str
Loading reference image…
self
printer
inc
# ref_frame
assert
abs
self
ref_frame
self
image_series
n_frames
abs(ref_frame) =
str
abs
self
ref_frame
str
self
image_series
n_frames
= image_series.n_frames. Aborting.
self
ref_frame
self
ref_frame
self
image_series
n_frames
self
printer
print_var
ref_frame
self
ref_frame
# Iref
self
Iref
dolfin
Expression
cppcode
ddic
get_ExprIm_cpp
im_dim
self
image_series
dimension
im_type
im
im_is_def
element
self
fe
self
ref_image_filename
self
image_series
get_image_filename
self
ref_frame
self
Iref
init_image
self
ref_image_filename
self
Iref_int
dolfin
assemble
self
Iref
self
dV
self
problem
mesh_V0
self
printer
print_var
Iref_int
self
Iref_int
self
Iref_norm
dolfin
assemble
self
Iref
2
self
dV
self
problem
mesh_V0
1.
2
assert
self
Iref_norm
0.
Iref_norm =
str
self
Iref_norm
<= 0. Aborting.
self
printer
print_var
Iref_norm
self
Iref_norm
# DIref
self
DIref
dolfin
Expression
cppcode
ddic
get_ExprIm_cpp
im_dim
self
image_series
dimension
im_type
grad
if
self
image_series
grad_basename
is
None
else
grad_no_deriv
im_is_def
element
self
ve
self
ref_image_grad_filename
self
image_series
get_image_grad_filename
self
ref_frame
self
DIref
init_image
self
self
printer
dec
self
printer
print_str
Defining deformed image…
self
scaling
numpy
array
1.
0.
if
self
dynamic_scaling
self
p
numpy
empty
2
2
self
q
numpy
empty
2
# Idef
self
Idef
dolfin
Expression
cppcode
ddic
get_ExprIm_cpp
im_dim
self
image_series
dimension
im_type
im
im_is_def
element
self
fe
self
Idef
init_image
self
ref_image_filename
self
Idef
init_disp
self
problem
U
self
Idef
init_dynamic_scaling
self
scaling
# DIdef
self
DIdef
dolfin
Expression
cppcode
ddic
get_ExprIm_cpp
im_dim
self
image_series
dimension
im_type
grad
if
self
image_series
grad_basename
is
None
else
grad_no_deriv
im_is_def
element
self
ve
self
DIdef
init_image
self
ref_image_filename
self
DIdef
init_disp
self
problem
U
self
DIdef
self
scaling
self
printer
print_str
Defining previous image…
# Iold
self
Iold
dolfin
Expression
cppcode
ddic
get_ExprIm_cpp
im_dim
self
image_series
dimension
im_type
im
im_is_def
element
self
fe
self
Iold
init_image
self
ref_image_filename
self
Iold
init_disp
self
problem
Uold
self
Iold
self
scaling
# 2016/07/25: ok, same scaling must apply to Idef & Iold…
# DIold
self
DIold
dolfin
Expression
cppcode
ddic
get_ExprIm_cpp
im_dim
self
image_series
dimension
im_type
grad
if
self
image_series
grad_basename
is
None
else
grad_no_deriv
im_is_def
element
self
ve
self
DIold
init_image
self
ref_image_filename
self
DIold
init_disp
self
problem
Uold
self
DIold
self
scaling
self
printer
print_str
Defining correlation energy…
# Phi_ref
self
Phi_Iref
dolfin
Expression
cppcode
ddic
get_ExprCharFuncIm_cpp
im_dim
self
image_series
dimension
element
self
fe
self
Phi_Iref
init_image
self
ref_image_filename
# Psi_c
self
Psi_c
self
Phi_Iref
self
Idef
self
Iref
2
2
self
DPsi_c
self
Phi_Iref
self
Idef
self
Iref
dolfin
dot
self
DIdef
self
problem
dU_test
self
DDPsi_c
self
Phi_Iref
dolfin
dot
self
DIdef
self
problem
dU_trial
dolfin
dot
self
DIdef
self
problem
dU_test
self
DDPsi_c_old
self
Phi_Iref
dolfin
dot
self
DIold
self
problem
dU_trial
dolfin
dot
self
DIold
self
problem
dU_test
self
DDPsi_c_ref
self
Phi_Iref
dolfin
dot
self
DIref
self
problem
dU_trial
dolfin
dot
self
DIref
self
problem
dU_test
self
Psi_c_old
self
Phi_Iref
self
Idef
self
Iold
2
2
self
DPsi_c_old
self
Phi_Iref
self
Idef
self
Iold
dolfin
dot
self
DIdef
self
problem
dU_test
# forms
self
ener_form
self
Psi_c
self
dV
self
res_form
self
DPsi_c
self
dV
self
jac_form
self
DDPsi_c
self
dV
self
printer
dec
def
reinit
self
self
scaling
1.
0.
def
call_before_solve
self
k_frame
k_frame_old
self
printer
print_str
Loading deformed image for correlation energy…
# Idef
self
def_image_filename
self
image_series
get_image_filename
k_frame
self
Idef
init_image
self
def_image_filename
# DIdef
self
def_grad_image_filename
self
image_series
k_frame
self
DIdef
init_image
self
self
printer
print_str
Loading previous image for correlation energy…
# Iold
self
old_image_filename
self
image_series
get_image_filename
k_frame_old
self
Iold
init_image
self
old_image_filename
# DIold
self
old_grad_image_filename
self
image_series
k_frame_old
self
DIold
init_image
self
def
call_after_solve
self
pass
def
get_qoi_names
self
return
self
name
_ener
self
name
_err
def
get_qoi_values
self
self
ener
dolfin
assemble
self
ener_form
self
problem
mesh_V0
1.
2
self
printer
print_sci
self
name
_ener
self
ener
self
err
self
ener
self
Iref_norm
self
printer
print_sci
self
name
_err
self
err
return
self
ener
self
err
This diff is collapsed.
Loading
Save comment
