Commit 9aec4ae2 authored by Martin Genet's avatar Martin Genet
Merge branch 'master' into GIMIC
parents f4359117 01cc537c
...@@ -16,6 +16,7 @@ from Energy_Regularization import * ...@@ -16,6 +16,7 @@ from Energy_Regularization import *
from compute_warped_images import * from compute_warped_images import *
from plot_strains import * from plot_strains import *
from image_expressions_cpp import * from image_expressions_cpp import *
from plot_twist_vs_height import *
from Energy import * from Energy import *
from compute_warped_mesh import * from compute_warped_mesh import *
from Energy_WarpedImage import * from Energy_WarpedImage import *
...@@ -10,10 +10,12 @@ ...@@ -10,10 +10,12 @@
import dolfin import dolfin
import glob import glob
import math
import numpy import numpy
import myPythonLibrary as mypy import myPythonLibrary as mypy
import myVTKPythonLibrary as myvtk import myVTKPythonLibrary as myvtk
import vtkpython_cbl as cbl
import dolfin_dic as ddic import dolfin_dic as ddic
...@@ -23,50 +25,78 @@ def compute_strains( ...@@ -23,50 +25,78 @@ def compute_strains(
working_folder, working_folder,
working_basename, working_basename,
working_ext="vtu", working_ext="vtu",
ref_frame=None, ref_frame=None, # MG20190612: Reference configuration.
disp_array_name="displacement", disp_array_name="displacement",
defo_grad_array_name="DeformationGradient", defo_grad_array_name="DeformationGradient",
strain_array_name="Strain", strain_array_name="Strain",
ref_mesh_folder=None, ref_mesh_folder=None, # MG20190612: Mesh with sectors/parts/etc.
ref_mesh_basename=None, ref_mesh_basename=None,
ref_mesh_ext="vtk", ref_mesh_ext="vtk",
CYL_or_PPS="PPS", CYL_or_PPS="PPS",
remove_boundary_layer=1,
in_place=1,
write_strains=1, write_strains=1,
temporal_offset=None, temporal_offset=None,
temporal_resolution=None, temporal_resolution=None,
plot_strains=1, plot_strains=1,
plot_regional_strains=0, plot_regional_strains=0,
write_strains_vs_radius=0, write_strains_vs_radius=0,
plot_strains_vs_radius=0,
write_binned_strains_vs_radius=0, write_binned_strains_vs_radius=0,
plot_binned_strains_vs_radius=0,
write_twist_vs_height=0,
plot_twist_vs_height=0,
verbose=1): verbose=1):
if (ref_mesh_folder is not None) and (ref_mesh_basename is not None): if (write_strains_vs_radius):
assert (remove_boundary_layer),\
"write_strains_vs_radius only works after removing the boundary layer. Aborting"
if (write_binned_strains_vs_radius):
"write_binned_strains_vs_radius only works after removing the boundary layer. Aborting"
if (write_twist_vs_height):
"write_twist_vs_height only works after removing the boundary layer. Aborting"
if (ref_mesh_folder is not None)\
ref_mesh_filename = ref_mesh_folder+"/"+ref_mesh_basename+"."+ref_mesh_ext
ref_mesh = myvtk.readUGrid( ref_mesh = myvtk.readUGrid(
filename=ref_mesh_folder+"/"+ref_mesh_basename+"."+ref_mesh_ext, filename=ref_mesh_filename,
verbose=verbose) verbose=verbose)
ref_mesh_n_points = ref_mesh.GetNumberOfPoints()
ref_mesh_n_cells = ref_mesh.GetNumberOfCells() ref_mesh_n_cells = ref_mesh.GetNumberOfCells()
if (verbose): print "ref_mesh_n_points = " + str(ref_mesh_n_points)
if (verbose): print "ref_mesh_n_cells = " + str(ref_mesh_n_cells) if (verbose): print "ref_mesh_n_cells = " + str(ref_mesh_n_cells)
if (ref_mesh.GetCellData().HasArray("part_id")):
iarray_ref_part_id = ref_mesh.GetCellData().GetArray("part_id")
n_part_ids = 0
for k_cell in xrange(ref_mesh_n_cells):
part_id = int(iarray_ref_part_id.GetTuple1(k_cell))
if (part_id > n_part_ids-1):
n_part_ids = part_id+1
if (verbose): print "n_part_ids = " + str(n_part_ids)
else:
iarray_ref_part_id = None
n_part_ids = 0
if (ref_mesh.GetCellData().HasArray("sector_id")): if (ref_mesh.GetCellData().HasArray("sector_id")):
iarray_sector_id = ref_mesh.GetCellData().GetArray("sector_id") iarray_ref_sector_id = ref_mesh.GetCellData().GetArray("sector_id")
n_sector_ids = 0 n_sector_ids = 0
for k_cell in xrange(ref_mesh_n_cells): for k_cell in xrange(ref_mesh_n_cells):
sector_id = int(iarray_sector_id.GetTuple1(k_cell)) sector_id = int(iarray_ref_sector_id.GetTuple1(k_cell))
if (sector_id < 0): continue if (sector_id < 0): continue
if (sector_id > n_sector_ids-1): if (sector_id > n_sector_ids-1):
n_sector_ids = sector_id+1 n_sector_ids = sector_id+1
if (verbose): print "n_sector_ids = " + str(n_sector_ids) if (verbose): print "n_sector_ids = " + str(n_sector_ids)
else: else:
iarray_sector_id = None iarray_ref_sector_id = None
part_id_array = ref_mesh.GetCellData().GetArray("part_id")
else:
part_id_array = None
else: else:
ref_mesh = None ref_mesh = None
n_part_ids = 0
working_filenames = glob.glob(working_folder+"/"+working_basename+"_[0-9]*."+working_ext) working_filenames = glob.glob(working_folder+"/"+working_basename+"_[0-9]*."+working_ext)
...@@ -83,23 +113,27 @@ def compute_strains( ...@@ -83,23 +113,27 @@ def compute_strains(
strain_file.write("#t Err_avg Err_std Ecc_avg Ecc_std Ell_avg Ell_std Erc_avg Erc_std Erl_avg Erl_std Ecl_avg Ecl_std\n") strain_file.write("#t Err_avg Err_std Ecc_avg Ecc_std Ell_avg Ell_std Erc_avg Erc_std Erl_avg Erl_std Ecl_avg Ecl_std\n")
if (write_strains_vs_radius): if (write_strains_vs_radius):
strain_vs_radius_file = open(working_folder+"/"+working_basename+"-strains_vs_radius.dat", "w") strains_vs_radius_file = open(working_folder+"/"+working_basename+"-strains_vs_radius.dat", "w")
strain_vs_radius_file.write("#t rr Err Ecc Ell Erc Erl Ecl\n") strains_vs_radius_file.write("#t rr Err Ecc Ell Erc Erl Ecl\n")
if (write_binned_strains_vs_radius): if (write_binned_strains_vs_radius):
binned_strain_vs_radius_file = open(working_folder+"/"+working_basename+"-binned_strains_vs_radius.dat", "w") binned_strains_vs_radius_file = open(working_folder+"/"+working_basename+"-binned_strains_vs_radius.dat", "w")
binned_strain_vs_radius_file.write("#t rr Err Ecc Ell Erc Erl Ecl\n") binned_strains_vs_radius_file.write("#t rr Err Ecc Ell Erc Erl Ecl\n")
twist_vs_height_file = open(working_folder+"/"+working_basename+"-twist_vs_height.dat", "w")
twist_vs_height_file.write("#t z beta\n")
if (ref_frame is not None): if (ref_frame is not None):
ref_mesh_filename = working_folder+"/"+working_basename+"_"+str(ref_frame).zfill(working_zfill)+"."+working_ext mesh0_filename = working_folder+"/"+working_basename+"_"+str(ref_frame).zfill(working_zfill)+"."+working_ext
ref_mesh = myvtk.readUGrid( mesh0 = myvtk.readUGrid(
filename=ref_mesh_filename, filename=mesh0_filename,
myvtk.addDeformationGradients( myvtk.addDeformationGradients(
mesh=ref_mesh, mesh=mesh0,
disp_array_name=disp_array_name, disp_array_name=disp_array_name,
farray_F0 = ref_mesh.GetCellData().GetArray(defo_grad_array_name) farray_F0 = mesh0.GetCellData().GetArray(defo_grad_array_name)
for k_frame in xrange(n_frames): for k_frame in xrange(n_frames):
print "k_frame = "+str(k_frame) print "k_frame = "+str(k_frame)
...@@ -108,13 +142,25 @@ def compute_strains( ...@@ -108,13 +142,25 @@ def compute_strains(
mesh = myvtk.readUGrid( mesh = myvtk.readUGrid(
filename=mesh_filename, filename=mesh_filename,
n_points = mesh.GetNumberOfPoints()
n_cells = mesh.GetNumberOfCells() n_cells = mesh.GetNumberOfCells()
if (ref_mesh is not None): if (ref_mesh is not None):
assert (n_cells == ref_mesh_n_cells), "ref_mesh_n_cells ("+str(ref_mesh_n_cells)+") ≠ n_cells ("+str(n_cells)+"). Aborting." assert (n_points == ref_mesh_n_points),\
if (part_id_array is not None): "ref_mesh_n_points ("+str(ref_mesh_n_points)+") ≠ n_points ("+str(n_points)+"). Aborting."
mesh.GetCellData().AddArray(part_id_array) assert (n_cells == ref_mesh_n_cells),\
if (iarray_sector_id is not None): "ref_mesh_n_cells ("+str(ref_mesh_n_cells)+") ≠ n_cells ("+str(n_cells)+"). Aborting."
mesh.GetCellData().AddArray(iarray_sector_id) if (iarray_ref_part_id is not None):
mesh.GetCellData().AddArray(iarray_ref_part_id)
if (iarray_ref_sector_id is not None):
mesh.GetCellData().AddArray(iarray_ref_sector_id)
if (write_strains_vs_radius )\
or (write_binned_strains_vs_radius):
assert (ref_mesh.GetCellData().HasArray("rr"))
mesh.GetCellData().AddArray(ref_mesh.GetCellData().GetArray("rr"))
assert (ref_mesh.GetPointData().HasArray("ll"))
mesh.GetPointData().AddArray(ref_mesh.GetPointData().GetArray("r"))
mesh.GetPointData().AddArray(ref_mesh.GetPointData().GetArray("ll"))
mesh=mesh, mesh=mesh,
...@@ -133,38 +179,62 @@ def compute_strains( ...@@ -133,38 +179,62 @@ def compute_strains(
strain_array_name=strain_array_name, strain_array_name=strain_array_name,
mesh_w_local_basis=ref_mesh, mesh_w_local_basis=ref_mesh,
if (ref_mesh is not None)\
and (iarray_ref_part_id is not None)\
and (remove_boundary_layer ):
mesh = myvtk.getThresholdedUGrid(
ugrid=mesh,
field_support="cells",
field_name="part_id",
threshold_value=0.5,
threshold_by_upper_or_lower="lower")
n_part_ids = 0
iarray_sector_id = mesh.GetCellData().GetArray("sector_id")
else:
iarray_sector_id = iarray_ref_sector_id
mesh_filename = working_folder+"/"+working_basename+("-wStrains")*(not in_place)+"_"+str(k_frame).zfill(working_zfill)+"."+working_ext
myvtk.writeUGrid( myvtk.writeUGrid(
ugrid=mesh, ugrid=mesh,
filename=working_folder+"/"+working_basename+"_"+str(k_frame).zfill(working_zfill)+"."+working_ext, filename=mesh_filename,
if (write_strains) or (write_strains_vs_radius) or (write_binned_strains_vs_radius): if (write_strains )\
if (ref_mesh is not None) and (mesh.GetCellData().HasArray(strain_array_name+"_"+CYL_or_PPS)): or (write_strains_vs_radius )\
farray_strain = mesh.GetCellData().GetArray(strain_array_name+"_"+CYL_or_PPS) farray_strain = mesh.GetCellData().GetArray(strain_array_name+"_"+CYL_or_PPS)
else: else:
farray_strain = mesh.GetCellData().GetArray(strain_array_name) farray_strain = mesh.GetCellData().GetArray(strain_array_name)
if (write_strains): if (write_strains):
if (n_sector_ids == 0): if (n_sector_ids in (0,1)):
strains_all = [] if (n_part_ids == 0):
for k_cell in xrange(n_cells): strains_all = [farray_strain.GetTuple(k_cell) for k_cell in xrange(n_cells)]
strains_all.append(farray_strain.GetTuple(k_cell)) else:
elif (n_sector_ids == 1): strains_all = [farray_strain.GetTuple(k_cell) for k_cell in xrange(n_cells) if (iarray_ref_part_id.GetTuple1(k_cell) > 0)]
strains_all = []
sector_id = int(iarray_sector_id.GetTuple(k_cell)[0])
elif (n_sector_ids > 1): elif (n_sector_ids > 1):
strains_all = [] strains_all = []
strains_per_sector = [[] for sector_id in xrange(n_sector_ids)] strains_per_sector = [[] for sector_id in xrange(n_sector_ids)]
for k_cell in xrange(n_cells): if (n_part_ids == 0):
sector_id = int(iarray_sector_id.GetTuple(k_cell)[0]) for k_cell in xrange(n_cells):
if (sector_id < 0): continue strains_all.append(farray_strain.GetTuple(k_cell))
strains_all.append(farray_strain.GetTuple(k_cell)) sector_id = int(iarray_sector_id.GetTuple1(k_cell))
strains_per_sector[sector_id].append(farray_strain.GetTuple(k_cell)) strains_per_sector[sector_id].append(farray_strain.GetTuple(k_cell))
else:
if (part_id > 0): continue
if (temporal_offset is not None) and (temporal_resolution is not None): if (temporal_offset is not None)\
strain_file.write(str(temporal_offset + k_frame*temporal_resolution)) strain_file.write(str(temporal_offset + k_frame*temporal_resolution))
else: else:
strain_file.write(str(k_frame)) strain_file.write(str(k_frame))
...@@ -179,16 +249,14 @@ def compute_strains( ...@@ -179,16 +249,14 @@ def compute_strains(
strain_file.write("\n") strain_file.write("\n")
assert (ref_mesh.GetCellData().HasArray("rr")) farray_rr = mesh.GetCellData().GetArray("rr")
farray_rr = ref_mesh.GetCellData().GetArray("rr")
for k_cell in xrange(n_cells): for k_cell in xrange(n_cells):
strain_vs_radius_file.write(" ".join([str(val) for val in [k_frame, farray_rr.GetTuple1(k_cell)]+list(farray_strain.GetTuple(k_cell))]) + "\n") strains_vs_radius_file.write(" ".join([str(val) for val in [k_frame, farray_rr.GetTuple1(k_cell)]+list(farray_strain.GetTuple(k_cell))]) + "\n")
strain_vs_radius_file.write("\n") strains_vs_radius_file.write("\n")
n_r = 10 n_r = 10
binned_strains = [[] for k_r in xrange(n_r)] binned_strains = [[] for k_r in xrange(n_r)]
...@@ -203,9 +271,63 @@ def compute_strains( ...@@ -203,9 +271,63 @@ def compute_strains(
#print binned_strains_avg #print binned_strains_avg
#print binned_strains_std #print binned_strains_std
for k_r in xrange(n_r): for k_r in xrange(n_r):
binned_strain_vs_radius_file.write(" ".join([str(val) for val in [k_frame, (k_r+0.5)/n_r]+[val for k_comp in xrange(6) for val in [binned_strains_avg[k_r][k_comp], binned_strains_std[k_r][k_comp]]]]) + "\n") binned_strains_vs_radius_file.write(" ".join([str(val) for val in [k_frame, (k_r+0.5)/n_r]+[val for k_comp in xrange(6) for val in [binned_strains_avg[k_r][k_comp], binned_strains_std[k_r][k_comp]]]]) + "\n")
binned_strain_vs_radius_file.write("\n") binned_strains_vs_radius_file.write("\n")
points_AB = cbl.getABPointsFromBoundsAndCenter(
mesh=mesh,
AB=[0,0,1],
verbose=verbose)
C = points_AB.GetPoint(0)
farray_r = mesh.GetPointData().GetArray("r")
farray_ll = mesh.GetPointData().GetArray("ll")
farray_U = mesh.GetPointData().GetArray(disp_array_name)
farray_Theta = myvtk.createFloatArray(
name="Theta",
n_components=1,
n_tuples=n_points)
farray_theta = myvtk.createFloatArray(
name="theta",
n_components=1,
n_tuples=n_points)
farray_beta = myvtk.createFloatArray(
name="beta",
n_components=1,
n_tuples=n_points)
mesh.GetPointData().AddArray(farray_Theta)
mesh.GetPointData().AddArray(farray_theta)
mesh.GetPointData().AddArray(farray_beta)
X = numpy.empty(3)
U = numpy.empty(3)
x = numpy.empty(3)
for k_point in xrange(n_points):
r = farray_r.GetTuple1(k_point)
ll = farray_ll.GetTuple1(k_point)
mesh.GetPoint(k_point, X)
X -= C
Theta = math.degrees(math.atan2(X[1], X[0]))
farray_U.GetTuple(k_point, U)
x[:] = X[:] + U[:]
theta = math.degrees(math.atan2(x[1], x[0]))
beta = theta - Theta
if (beta > +180.): beta -= 360.
if (beta < -180.): beta += 360.
farray_Theta.SetTuple1(k_point, Theta)
farray_theta.SetTuple1(k_point, theta)
farray_beta.SetTuple1(k_point, beta)
if (r < 15.): continue
# if (ll < 1./3): continue
twist_vs_height_file.write(" ".join([str(val) for val in [k_frame, ll, beta]]) + "\n")
myvtk.writeUGrid(
ugrid=mesh,
verbose=verbose)
twist_vs_height_file.write("\n")
strain_file.close() strain_file.close()
...@@ -225,7 +347,31 @@ def compute_strains( ...@@ -225,7 +347,31 @@ def compute_strains(
strain_vs_radius_file.close() strains_vs_radius_file.close()
if (plot_strains_vs_radius):
ddic.plot_strains_vs_radius(
working_folder=working_folder,
working_basenames=[working_basename],
suffix=None,
verbose=verbose)
binned_strain_vs_radius_file.close() binned_strains_vs_radius_file.close()
if (plot_binned_strains_vs_radius):
ddic.plot_binned_strains_vs_radius(
suffix=None,
verbose=verbose)
twist_vs_height_file.close()
if (plot_twist_vs_height):
ddic.plot_twist_vs_height(
working_basename=working_basename,
suffix=None,
verbose=verbose)
...@@ -21,6 +21,7 @@ def get_ExprIm_cpp( ...@@ -21,6 +21,7 @@ def get_ExprIm_cpp(
im_default_interpol_out_value="0.", im_default_interpol_out_value="0.",
grad_default_interpol_mode="linear", # linear, nearest grad_default_interpol_mode="linear", # linear, nearest
grad_default_interpol_out_value="0.", grad_default_interpol_out_value="0.",
static_scaling_factor=0,
verbose=0): verbose=0):
assert (im_dim in (2,3)) assert (im_dim in (2,3))
...@@ -121,9 +122,10 @@ public: ...@@ -121,9 +122,10 @@ public:
vtkSmartPointer<vtkXMLImageDataReader> reader = vtkSmartPointer<vtkXMLImageDataReader>::New(); vtkSmartPointer<vtkXMLImageDataReader> reader = vtkSmartPointer<vtkXMLImageDataReader>::New();
reader->SetFileName(filename); reader->SetFileName(filename);
reader->Update(); reader->Update();'''+('''
static_scaling = getStaticScalingFactor(reader->GetOutput()->GetScalarTypeAsString());'''+(''' static_scaling = getStaticScalingFactor(reader->GetOutput()->GetScalarTypeAsString());''')*(not static_scaling_factor)+('''
static_scaling = '''+str(static_scaling_factor)+''';''')*(static_scaling_factor)+('''
vtkSmartPointer<vtkImageGradient> gradient = vtkSmartPointer<vtkImageGradient>::New(); vtkSmartPointer<vtkImageGradient> gradient = vtkSmartPointer<vtkImageGradient>::New();
#if VTK_MAJOR_VERSION >= 6 #if VTK_MAJOR_VERSION >= 6
...@@ -23,10 +23,10 @@ def plot_binned_strains_vs_radius( ...@@ -23,10 +23,10 @@ def plot_binned_strains_vs_radius(
if (ref_folder is not None) and (ref_basename is not None): if (ref_folder is not None) and (ref_basename is not None):
lines = open(ref_folder+"/"+ref_basename+"-strains.dat").readlines() lines = open(ref_folder+"/"+ref_basename+"-strains.dat").readlines()[1:]
else: else:
lines = open(working_folder+"/"+working_basenames[0]+"-strains.dat").readlines() lines = open(working_folder+"/"+working_basenames[0]+"-strains.dat").readlines()[1:]
n_frames = len(lines)-1 n_frames = len(lines)
assert (components in ("all", "circ-long", "rad-circ")) assert (components in ("all", "circ-long", "rad-circ"))
if (components == "all"): if (components == "all"):
#coding=utf8
### Created by Martin Genet, 2016-2019 ###
### École Polytechnique, Palaiseau, France ###
import os
def plot_twist_vs_height(
working_folder,
working_basename,
beta_range=15.,
suffix="",
verbose=1):
lines = open(working_folder+"/"+working_basename+"-strains.dat").readlines()[1:]
if (suffix is None):
plotfile_basename = working_folder+"/"+working_basename+"-twist_vs_height"
else:
plotfile_basename = "plot_twist_vs_height"+("-"+suffix)*(suffix!="")
plotfile = open(plotfile_basename+".plt", "w")
plotfile.write('''\
set terminal pdf enhanced
load "Set1.plt"
set output "'''+plotfile_basename+'''.pdf"
set key off
# set key box textcolor variable width +0
set grid
set xlabel "beta (deg)"
xrange = '''+str(beta_range)+'''
set xrange [-xrange:+xrange]
# set ylabel "ll ()"
set yrange [0.:1.]
set ytics("apex" 0, "base" 1)
# f(x) = a*x + b
# g(x) = x/c - d/c
# h(x) = c*x + d
g(x) = c*x + d
h(x) = x/c - d/c
# FIT_MAXITER = 10
datafile = "'''+working_folder+'''/'''+working_basename+'''-twist_vs_height.dat"
plotfile.write('''\
# a = 1.
# b = 0.5
# c = 1.
# d = 0.5
c = 1.
d = -0.5*c
set title "index '''+str(k_frame)+'''"
# fit f(x) datafile using 3:2 index '''+str(k_frame)+''' via a,b
'''+('''# ''')*(k_frame==0)+'''fit g(x) datafile using 2:3 index '''+str(k_frame)+''' via c,d
plot datafile using 3:2 index '''+str(k_frame)+''' notitle, h(x) notitle
plotfile.close()
os.system("gnuplot "+plotfile_basename+".plt")
