GitLab
Explore
Primary navigation
Search or go to…
dolfin_warp
Manage
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Operate
Terraform modules
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Martin Genet
dolfin_warp
7404729a
7404729a
6 years ago
PATTE Cecile
Downloads
Patches
Add the case where the image is deformed and the displacement comes from a vtu file
06d6cb72
1 merge request
!2
image_expressions_cpp.py
+43
-6
43 additions, 6 deletions
43 additions
6 deletions
43
6
7404729a
@@ -14,6 +14,7 @@ def get_ExprIm_cpp(
im_dim
im_type
im
im_is_def
u_is_vtk
verbose
assert
im_dim
in
2
3
@@ -28,6 +29,14 @@ def get_ExprIm_cpp(
#include <vtkImageData.h>
#include <vtkImageGradient.h>
im_type
grad
#include <vtkImageInterpolator.h>
#include <vtkUnstructuredGridReader.h>
#include <vtkXMLUnstructuredGridReader.h>
#include <vtkUnstructuredGrid.h>
#include <vtkProbeFilter.h>
#include <vtkPointData.h>
#include <vtkDataArray.h>
#include <vtkPolyData.h>
double getStaticScalingFactor(const char* scalar_type_as_string)
@@ -49,8 +58,11 @@ class MyExpr : public Expression
double static_scaling;
Array<double>* dynamic_scaling; // does not work
double dynamic_scaling_a; // should not be needed
double dynamic_scaling_b; // should not be needed
Function* U;
Function* U;
not
u_is_vtk
vtkSmartPointer<vtkProbeFilter> probe_filter;
vtkSmartPointer<vtkPoints> probe_points;
vtkSmartPointer<vtkPolyData> probe_polydata;
u_is_vtk
mutable Array<double> UX;
mutable Array<double> x;
im_is_def
mutable Array<double> X3D;
not
im_is_def
im_dim
2
@@ -64,7 +76,10 @@ public:
UX(
str
im_dim
x(3)
im_is_def
X3D(3)
not
im_is_def
im_dim
2
probe_filter = vtkSmartPointer<vtkProbeFilter>::New();
probe_points = vtkSmartPointer<vtkPoints>::New();
probe_polydata = vtkSmartPointer<vtkPolyData>::New();
u_is_vtk
void init_dynamic_scaling(
@@ -83,11 +98,24 @@ public:
dynamic_scaling_b = scaling[1]; // should not be needed
} // should not be needed
void init_disp(
Function* UU)
U = UU;
im_is_def
not
u_is_vtk
void init_disp(
const char* mesh_filename)
vtkSmartPointer<vtkXMLUnstructuredGridReader> reader = vtkSmartPointer<vtkXMLUnstructuredGridReader>::New();
reader->SetFileName(mesh_filename);
reader->Update();
vtkSmartPointer<vtkUnstructuredGrid> mesh = reader->GetOutput();
probe_filter->SetSourceData(mesh);
probe_points->SetNumberOfPoints(1);
u_is_vtk
im_is_def
void init_image(
const char* filename,
@@ -139,9 +167,17 @@ public:
void eval(Array<double>& expr, const Array<double>& X) const
std::cout <<
X =
<< X.str(1) << std::endl;
verbose
std::cout <<
X =
verbose
U->eval(UX, X);
U->eval(UX, X);
not
u_is_vtk
probe_points->SetPoint(0,X.data());
probe_polydata->SetPoints(probe_points);
probe_filter->SetInputData(probe_polydata);
probe_filter->Update();
probe_filter->GetOutput()->GetPointData()->GetArray(
U
)->GetTuple(0, UX.data());
u_is_vtk
std::cout <<
UX =
<< UX.str(1) << std::endl;
verbose
x[0] = X[0] + UX[0];
x[1] = X[1] + UX[1];
im_dim
2
@@ -208,6 +244,7 @@ public:
#print ExprIm_cpp
return
ExprIm_cpp
def
get_ExprCharFuncIm_cpp
im_dim
verbose
This diff is collapsed.
Loading
Save comment
