GitLab
Explore
Primary navigation
Search or go to…
dolfin_warp
Manage
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Operate
Terraform modules
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Martin Genet
dolfin_warp
190669f0
190669f0
8 years ago
Martin Genet
Downloads
Patches
Adding choice to write or not the strain file (similar to the strain_vs_radius file)
1c6b33f4
Branches containing commit
Tags containing commit
compute_strains.py
+41
-37
41 additions, 37 deletions
compute_strains.py
41 additions
37 deletions
compute_strains.py
41
37
190669f0
@@ -23,6 +23,7 @@ def compute_strains(
ref_folder
None
ref_folder
None
ref_basename
None
ref_basename
None
CYL_or_PPS
PPS
CYL_or_PPS
PPS
write_strains
write_strain_vs_radius
verbose
verbose
@@ -53,8 +54,9 @@ def compute_strains(
n_zfill
len
glob
glob
sol_folder
sol_basename
_*.
sol_ext
rsplit
_
split
n_zfill
len
glob
glob
sol_folder
sol_basename
_*.
sol_ext
rsplit
_
split
if
verbose
print
n_zfill =
str
n_zfill
if
verbose
print
n_zfill =
str
n_zfill
strain_file
open
sol_folder
sol_basename
-strains.dat
w
if
write_strains
strain_file
write
#t Err_avg Err_std Ecc_avg Ecc_std Ell_avg Ell_std Erc_avg Erc_std Erl_avg Erl_std Ecl_avg Ecl_std
\n
strain_file
open
sol_folder
sol_basename
-strains.dat
w
strain_file
write
\n
if
if
strain_vs_radius_file
open
sol_folder
sol_basename
-strains_vs_radius.dat
w
open
sol_folder
sol_basename
w
@@ -79,41 +81,43 @@ def compute_strains(
filename
sol_folder
sol_basename
_
str
k_frame
zfill
n_zfill
sol_ext
filename
sol_folder
sol_basename
_
str
k_frame
zfill
n_zfill
sol_ext
verbose
verbose
if
ref_mesh
is
not
None
if
write_strains
assert
mesh
GetCellData
HasArray
Strain_
CYL_or_PPS
if
ref_mesh
is
not
None
farray_strain
mesh
GetCellData
GetArray
Strain_
CYL_or_PPS
assert
mesh
GetCellData
HasArray
Strain_
CYL_or_PPS
else
farray_strain
mesh
GetCellData
GetArray
Strain_
CYL_or_PPS
farray_strain
mesh
GetCellData
GetArray
Strain
else
farray_strain
mesh
GetCellData
GetArray
Strain
if
n_sector_ids
strains_all
if
write_strains
for
k_cell
in
xrange
n_cells
if
n_sector_ids
strains_all
append
farray_strain
GetTuple
k_cell
strains_all
elif
n_sector_ids
for
k_cell
in
xrange
n_cells
strains_all
strains_all
append
farray_strain
GetTuple
k_cell
for
k_cell
in
xrange
n_cells
elif
n_sector_ids
sector_id
int
iarray_sector_id
GetTuple
k_cell
strains_all
if
sector_id
continue
for
k_cell
in
xrange
n_cells
strains_all
append
farray_strain
GetTuple
k_cell
sector_id
int
iarray_sector_id
GetTuple
k_cell
elif
n_sector_ids
if
sector_id
continue
strains_all
strains_all
append
farray_strain
GetTuple
k_cell
strains_per_sector
for
sector_id
in
xrange
n_sector_ids
elif
n_sector_ids
for
k_cell
in
xrange
n_cells
strains_all
sector_id
int
iarray_sector_id
GetTuple
k_cell
strains_per_sector
for
sector_id
in
xrange
n_sector_ids
if
sector_id
continue
for
k_cell
in
xrange
n_cells
strains_all
append
farray_strain
GetTuple
k_cell
sector_id
int
iarray_sector_id
GetTuple
k_cell
strains_per_sector
sector_id
append
farray_strain
GetTuple
k_cell
if
sector_id
continue
strains_all
append
farray_strain
GetTuple
k_cell
strain_file
write
str
k_frame
strains_per_sector
sector_id
append
farray_strain
GetTuple
k_cell
strains_all_avg
numpy
mean
strains_all
strains_all_std
numpy
std
strains_all
strain_file
write
str
k_frame
strain_file
write
join
str
strains_all_avg
k_comp
str
strains_all_std
k_comp
for
k_comp
in
xrange
6
strains_all_avg
numpy
mean
strains_all
if
n_sector_ids
strains_all_std
numpy
std
strains_all
for
sector_id
in
xrange
n_sector_ids
strain_file
write
join
str
strains_all_avg
k_comp
str
strains_all_std
k_comp
for
k_comp
in
xrange
6
strains_per_sector_avg
numpy
mean
strains_per_sector
sector_id
if
n_sector_ids
strains_per_sector_std
numpy
std
strains_per_sector
sector_id
for
sector_id
in
xrange
n_sector_ids
strain_file
write
join
str
k_comp
str
k_comp
for
k_comp
in
xrange
6
numpy
mean
strains_per_sector
sector_id
strain_file
write
\n
numpy
std
strains_per_sector
sector_id
strain_file
write
join
str
k_comp
str
k_comp
for
k_comp
in
xrange
6
strain_file
write
\n
if
if
assert
ref_mesh
GetCellData
HasArray
r
assert
ref_mesh
GetCellData
HasArray
r
This diff is collapsed.
Loading
Save comment
