GitLab
Explore
Primary navigation
Search or go to…
dolfin_warp
Manage
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Operate
Terraform modules
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Martin Genet
dolfin_warp
0ad52f41
0ad52f41
8 years ago
Martin Genet
Downloads
Patches
add possibility to choose image quadrature type at fedic call
e08bf217
fedic.py
+14
-4
14 additions, 4 deletions
fedic.py
14 additions
4 deletions
fedic.py
14
4
0ad52f41
@@ -43,6 +43,7 @@ def fedic(
images_n_frames
None
images_n_frames
None
images_ref_frame
images_ref_frame
images_quadrature
None
images_quadrature
None
images_quadrature_from
points_count
# points_count, integral
images_expressions_type
cpp
# cpp, py
cpp
# cpp, py
images_dynamic_scaling
mesh
None
mesh
None
@@ -103,10 +104,19 @@ def fedic(
mypy
print_str
tab
Computing quadrature degree for images…
mypy
print_str
tab
ref_image_filename
images_folder
images_basename
_
str
images_ref_frame
zfill
images_zfill
images_ext
ref_image_filename
images_folder
images_basename
_
str
images_ref_frame
zfill
images_zfill
images_ext
if
images_quadrature
is
None
if
images_quadrature
is
None
images_quadrature
ddic
compute_quadrature_degree_from_points_count
if
points_count
image_filename
ref_image_filename
images_quadrature
ddic
mesh_filebasename
mesh_filebasename
image_filename
ref_image_filename
verbose
mesh_filebasename
mesh_filebasename
verbose
elif
integral
images_quadrature
ddic
compute_quadrature_degree_from_integral
image_filename
ref_image_filename
mesh
mesh
deg_min
deg_max
10
tol
1e-2
verbose
mypy
print_var
tab
images_quadrature
images_quadrature
mypy
print_var
tab
images_quadrature
images_quadrature
mypy
print_str
tab
Loading reference image…
mypy
print_str
tab
This diff is collapsed.
Loading
Save comment
