Verified Commit 74d6808f authored by ANDREY Paul's avatar ANDREY Paul
Adjust TensorflowVector square and square root computations.
For some reason, `tf.square(x)` and `tf.pow(x, 2)` can result in
distinct values for small-enough values of x. The same is true of
`tf.sqrt(x)` and `tf.pow(x, 0.5)`.
This commit ensures the `tf.sqrt` and `tf.square` functions are
used in these two edge cases for the `vector ** p` syntax. This
choice is motivated by the fact that these functions are used
in most official tensorflow / keras code, and seem to be closer
to their torch counterparts (which are equivalent to `vec ** p`)
than `tf.pow` - based on a few local tests.
parent 3c82f5ce
1 merge request!15Implement framework-specific OptiModule subclasses.
...@@ -227,3 +227,16 @@ class TensorflowVector(Vector): ...@@ -227,3 +227,16 @@ class TensorflowVector(Vector):
keepdims: bool = False, keepdims: bool = False,
) -> Self: ) -> Self:
return self.apply_func(tf.reduce_sum, axis=axis, keepdims=keepdims) return self.apply_func(tf.reduce_sum, axis=axis, keepdims=keepdims)
def __pow__(
self,
other: Any,
) -> Self:
# For square and square root, use dedicated functions rather
# than tf.pow as results tend to differ for small values.
if isinstance(other, (int, float)):
if other == 2:
return self.apply_func(tf.square)
if other == 0.5:
return self.apply_func(tf.sqrt)
return super().__pow__(other)
