Commit 1bf6a11b authored by ANDREY Paul's avatar ANDREY Paul
Merge branch 'coverage' into 'develop'
Compute coverage as part of CI/CD.
See merge request !38
parents 34779af9 d6fe02b4
1 merge request!38Compute coverage as part of CI/CD.
Pipeline #778598 canceled
...@@ -12,6 +12,11 @@ test: ...@@ -12,6 +12,11 @@ test:
script: script:
- pip install -U tox - pip install -U tox
- tox -e py38 - tox -e py38
artifacts:
reports:
coverage_report:
coverage_format: cobertura
path: coverage.xml
rules: rules:
- if: ($CI_PIPELINE_SOURCE == "push") && - if: ($CI_PIPELINE_SOURCE == "push") &&
(($CI_COMMIT_BRANCH == "develop") || ($CI_COMMIT_BRANCH =~ "/^r\d\.\d+/")) (($CI_COMMIT_BRANCH == "develop") || ($CI_COMMIT_BRANCH =~ "/^r\d\.\d+/"))
...@@ -26,6 +31,11 @@ test-full: ...@@ -26,6 +31,11 @@ test-full:
script: script:
- tox -e py38 -- --fulltest - tox -e py38 -- --fulltest
artifacts:
reports:
coverage_report:
path: coverage.xml
rules: rules:
- if: ($CI_PIPELINE_SOURCE == "merge_request_event") && - if: ($CI_PIPELINE_SOURCE == "merge_request_event") &&
($CI_MERGE_REQUEST_TITLE !~ /^Draft:.*/) ($CI_MERGE_REQUEST_TITLE !~ /^Draft:.*/)
...@@ -86,6 +86,7 @@ tests = [ ...@@ -86,6 +86,7 @@ tests = [
"pylint >= 2.14", "pylint >= 2.14",
"pytest >= 6.1", "pytest >= 6.1",
"pytest-asyncio", "pytest-asyncio",
"pytest-cov >= 4.0",
[project.urls] [project.urls]
...@@ -96,6 +97,21 @@ repository = "https://gitlab.inria.fr/magnet/declearn/declearn2.git" ...@@ -96,6 +97,21 @@ repository = "https://gitlab.inria.fr/magnet/declearn/declearn2.git"
line-length = 79 line-length = 79
extend-exclude = "(.*_pb2.*py$)" # exclude auto-generated protobuf code files extend-exclude = "(.*_pb2.*py$)" # exclude auto-generated protobuf code files
[tool.coverage.run]
# enable coverage collection within multiprocessing
concurrency = ["multiprocessing"]
parallel = true
sigterm = true
# define rules to select the code files that need covering
source_pkgs = ["declearn"]
omit = [
"**/grpc/protobufs/*.py", # auto-generated rotobuf code files
"**/test_utils/*.py", # dev-only test-oriented utils
[tool.coverage.paths]
source = ["declearn", ".tox/**/declearn"]
[tool.mypy] [tool.mypy]
exclude = [".*_pb2.*.py$"] exclude = [".*_pb2.*.py$"]
follow_imports = "skip" # otherwise excluded files are checked follow_imports = "skip" # otherwise excluded files are checked
...@@ -12,11 +12,15 @@ allowlist_externals = ...@@ -12,11 +12,15 @@ allowlist_externals =
commands= commands=
# run unit tests first # run unit tests first
pytest {posargs} \ pytest {posargs} \
--cov --cov-report= \ # reset then accumulate coverage quietly
--ignore=test/functional/ \ --ignore=test/functional/ \
test test
# run functional tests (that build on units) # run functional tests (that build on units)
--cov --cov-append --cov-report=term \ # acc. and display coverage
test/functional/ test/functional/
# export the finalized coverage report to xml
coverage xml
# verify code acceptance by pylint # verify code acceptance by pylint
pylint declearn pylint declearn
pylint --recursive=y test pylint --recursive=y test
