GitLab
Explore
Primary navigation
Search or go to…
biocham
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container Registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Lifeware
biocham
a3e1b2ac
a3e1b2ac
2 months ago
HEMERY Mathieu
Downloads
Patches
%load magic add an extra cell after loading
869db549
biocham_jupyter/kernel/biocham_kernel/kernel.py
+8
-3
8 additions, 3 deletions
8 additions
3 deletions
8
3
a3e1b2ac
@@ -207,11 +207,16 @@ class BiochamKernel(IPythonKernel): # pylint: disable=too-many-ancestors
open
bcfile
r
as
bcinput
lines
bcinput
read
split
\n
# create a cell after current cell for each dotted command
return
loading {}
format
bcfile
empty_cell
source
set_next_input
text
line
strip
text
replace
False
for
line
in
reversed
lines
if
line
strip
command_cells
source
set_next_input
text
line
strip
replace
False
for
line
in
reversed
lines
if
line
strip
return
loading {}
format
bcfile
empty_cell
command_cells
except
FileNotFoundError
return
File doesn
t exists
This diff is collapsed.
Loading
Save comment
