GitLab
Explore
Primary navigation
Search or go to…
D
Deep_Learning_tutorial
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.4.
Show more breadcrumbs
CHOI Kwon-Young
df7d89b8
df7d89b8
7 years ago
CHOI Kwon-Young
Downloads
Patches
Update README.md
8acbc166
README.md
+44
-8
44 additions, 8 deletions
README.md
44 additions
8 deletions
README.md
44
8
df7d89b8
@@ -8,7 +8,7 @@ This repository contains materials for the Deep Learning tutorial of the Intuido
You will need a working
`ssh`
with private and public key pairs.
`ssh`
#### Windows:
For
Windows
users
Install git for windows https://git-scm.com/downloads.
This will install
`Git Bash`
with the three programs you will need:
`ssh`
`ssh-keygen`
`ssh-copy-id`
This will install
`Git Bash`
`ssh`
`ssh-keygen`
`ssh-copy-id`
@@ -26,25 +26,61 @@ Maintenant, vous pouvez vous connecter sur le front-end de la grille en utilisan
ssh
$USER
@igrida-oar-frontend
ssh
$USER
Launching
jobs
## Launching
IGRIDA jobs for the tutorial
In order to launch jobs on IGRIDA, you need to submit jobs using the
`oarsub`
command:
`oarsub`
command:
bash
bash
oarsub
-I
# create the job
oarsub
-S
-t
timesharing
-l
/nodes
1/core
4/gpu_device
1,walltime
01:30:0 scripts/run_igrida_staller.sh
# connect to it using the OAR_JOB_ID, you can list your jobs with oarstat -u
oarsub
-C
JOB_ID
This will launch a _interactive_ job for _10 minutes_ on _any_ node/server of IGRIDA with only _1 core_ allocated to you
You can find the script
`scripts/run_igrida_staller.sh`
here
#### On GPU node
More info at http://igrida.gforge.inria.fr/
## Clone the project
To launch a job using one gpu on any gpu node with a duration of 30 minutes
You can now clone the project on igrida with git
bash
bash
oarsub
-I
-l
/gpu_device
1,walltime
0:30:0
cd
where_ever_you_want
git clone https://gitlab.inria.fr/kchoi/Deep_Learning_tutorial.git
## Load python environment and the jupyter notebook
You can source the python environment using the following command:
bash
# replace gpu by cpu if on an cpu only node
source
/temp_dd/igrida-fs1/kchoi/miniconda3/bin/activate gpu
Next, run the jupyter notebook from which we will be doing the tutorial:
bash
jupyter notebook
--ip
--no-browser
# output
W 20:14:43.648 NotebookApp] WARNING: The notebook server is listening on all IP addresses and not using encryption. This is not recommended.
I 20:14:43.681 NotebookApp] Serving notebooks from
local
directory: /udd/user
I 20:14:43.681 NotebookApp] 0 active kernels
I 20:14:43.682 NotebookApp] The Jupyter Notebook is running at:
I 20:14:43.682 NotebookApp] http://[all ip addresses on your system]:8888/?token
ad046861594b9231e8f9c82860e7b25ca13d7637aee7aee5
I 20:14:43.682 NotebookApp] Use Control-C to stop this server and shut down all kernels
twice to skip confirmation
C 20:14:43.684 NotebookApp]
Copy/paste this URL into your browser when you connect
for
the first
time
to login with a token:
http://localhost:8888/?token
ad046861594b92...
Follow the output of the command and connect to the link
`http://igrida-abacus:8888/?token=ad046861594b923...`
Remember to replace
`localhost`
to the server you actually are running a job on.
Once you have loaded the jupyter notebook on your browser, you can start the tutorial by the opening the first
notebook
That's all for now, happy tutorial!
\ No newline at end of file
This diff is collapsed.
Loading
Save comment
