GitLab
Explore
Primary navigation
Search or go to…
A
aevol-eukaryotes
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
LUISELLI Juliette
aevol-eukaryotes
cc8ffd48
cc8ffd48
5 years ago
ROUZAUD-CORNABAS Jonathan
Downloads
Merge branch 'aevol_6' of gitlab.inria.fr:aevol/aevol into aevol_6
parents
2af4923d
ddda7f2d
Branches containing commit
Tags containing commit
CMakeLists.txt
+29
-1
29 additions, 1 deletion
CMakeLists.txt
29 additions
1 deletion
CMakeLists.txt
29
cc8ffd48
@@ -29,6 +29,10 @@ set(with-detectclone ON CACHE BOOL "Whether to enable clones and not recompute t
set
with-floatconcentration OFF CACHE BOOL
"Whether to enable the encoding of concentration has float (and not double)"
set
with-simd OFF CACHE BOOL
"Whether to switch to the SIMD implementation of (R-)Aevol"
if
APPLE
include_directories
AFTER
"/opt/X11/include"
endif
if
with-x
FIND_PACKAGE
X11 REQUIRED
if
X11_FOUND
@@ -42,12 +46,36 @@ else ()
message
"graphical output disable"
endif
if
APPLE
if
CMAKE_C_COMPILER_ID STREQUAL
"Clang"
OR
"AppleClang"
set
OpenMP_C
CMAKE_C_COMPILER
set
OpenMP_C_FLAGS
"-Xpreprocessor -fopenmp -Wno-unused-command-line-argument"
set
OpenMP_C_LIB_NAMES
"libomp"
"libgomp"
"libiomp5"
set
OpenMP_libomp_LIBRARY
OpenMP_C_LIB_NAMES
set
OpenMP_libgomp_LIBRARY
OpenMP_C_LIB_NAMES
set
OpenMP_libiomp5_LIBRARY
OpenMP_C_LIB_NAMES
endif
if
CMAKE_CXX_COMPILER_ID STREQUAL
"Clang"
OR
"AppleClang"
set
OpenMP_CXX
CMAKE_CXX_COMPILER
set
OpenMP_CXX_FLAGS
set
OpenMP_CXX_LIB_NAMES
"libomp"
"libgomp"
"libiomp5"
set
set
set
endif
endif
if
with-omp
find_package
OpenMP REQUIRED
if
OPENMP_FOUND
set
CMAKE_C_FLAGS
CMAKE_C_FLAGS
OpenMP_C_FLAGS
set
CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS
OpenMP_CXX_FLAGS
set
CMAKE_EXE_LINKER_FLAGS
OpenMP_EXE_LINKER_FLAGS
set
/usr/local/lib/libomp.dylib
endif
endif
This diff is collapsed.
Loading
Save comment
