GitLab
Explore
Primary navigation
Search or go to…
A
aevol-eukaryotes
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
LUISELLI Juliette
aevol-eukaryotes
a9408419
a9408419
2 years ago
LUISELLI Juliette
Committed by
David Parsons
1 year ago
Downloads
Patches
make sure no mutation occurs at the breaking point
bdb9f991
Branches containing commit
src/libaevol/7/DnaMutator.cpp
+23
-3
23 additions, 3 deletions
23 additions
3 deletions
23
3
a9408419
@@ -165,9 +165,14 @@ MutationEvent* DnaMutator::generate_next_mutation(int32_t length) {
if
pos_1
pos_2
if
pos_1
pos_2
seqlen
pos_2
pos_1
seqlen
pos_2
pos_1
else
else
int32_t
tmp1_len
length_
pos_1
#ifdef __EUKARYOTE
int32_t
tmp2_len
pos_2
Utils
exchange
pos_1
pos_2
seqlen
tmp1_len
tmp2_len
seqlen
pos_2
pos_1
#else
int32_t
tmp1_len
length_
pos_1
int32_t
tmp2_len
pos_2
seqlen
tmp1_len
tmp2_len
#endif
int32_t
genome_size_after
length_
seqlen
int32_t
genome_size_after
length_
seqlen
@@ -206,8 +211,13 @@ MutationEvent* DnaMutator::generate_next_mutation(int32_t length) {
if
pos_1
pos_2
if
pos_1
pos_2
genome_size_after
length_
pos_2
pos_1
genome_size_after
length_
pos_2
pos_1
else
else
#ifdef __EUKARYOTE
Utils
exchange
pos_1
pos_2
genome_size_after
length_
pos_2
pos_1
#else
genome_size_after
length_
length_
pos_1
genome_size_after
length_
length_
pos_1
genome_size_after
genome_size_after
pos_2
genome_size_after
genome_size_after
pos_2
#endif
// printf("Remove %d %d : LB %d LA %d\n",pos_1,pos_2,length_,genome_size_after);
@@ -226,6 +236,9 @@ MutationEvent* DnaMutator::generate_next_mutation(int32_t length) {
else
if
random_value
nb_large_dupl_
nb_large_del_
nb_large_trans_
else
if
random_value
nb_large_dupl_
nb_large_del_
nb_large_trans_
#ifdef __EUKARYOTE
std
cout
"Warning : performing a translocation with a eukaryotic individual"
std
endl
#endif
nb_large_trans_
nb_large_trans_
if
length_
if
length_
@@ -292,6 +305,7 @@ MutationEvent* DnaMutator::generate_next_mutation(int32_t length) {
// if (pos_1 == pos_2) return nullptr; // Invert everything <=> Invert nothing!
// Invert the segment that don't contain OriC
// Convenient for prokaryotes, absolutely necessary for eukaryotes
if
pos_1
pos_2
Utils
exchange
pos_1
pos_2
if
pos_1
pos_2
Utils
exchange
pos_1
pos_2
mevent
new
MutationEvent
mevent
new
MutationEvent
@@ -374,6 +388,12 @@ MutationEvent* DnaMutator::generate_next_mutation(int32_t length) {
if
length_
nb_pos_to_del
min_genome_length_
if
length_
nb_pos_to_del
min_genome_length_
return
nullptr
return
nullptr
#ifdef __EUKARYOTE
if
pos
nb_pos_to_del
length_
nb_pos_to_del
length_
pos
// Doing the maximal possible deletion
#endif
length_
length_
nb_pos_to_del
length_
length_
nb_pos_to_del
This diff is collapsed.
Loading
Save comment
