Commit 957601bf authored by ROUZAUD-CORNABAS Jonathan's avatar ROUZAUD-CORNABAS Jonathan
[ExpManager] check_simd (allowing to verify Aevol 6 results against Aevol 7)...
[ExpManager] check_simd (allowing to verify Aevol 6 results against Aevol 7) should be desactivated by default
parent bcf3560b
...@@ -223,7 +223,7 @@ class ExpManager : public Observer { ...@@ -223,7 +223,7 @@ class ExpManager : public Observer {
bool first_gen = true; bool first_gen = true;
bool check_simd_ = true; bool check_simd_ = false;
//wether you stop the simulation based on the age of mrca or not //wether you stop the simulation based on the age of mrca or not
bool with_mrca_ = false; bool with_mrca_ = false;
