Commit 531dc99b authored by David Parsons's avatar David Parsons
get rid of global cmd-line option variables
# Conflicts:
#	src/aevol_create.cpp
parent 470640be
......@@ -35,6 +35,7 @@
#include <list>
#include <sstream>
#include <string>
#include <tuple>
#include "legacy/ExpManager.h"
#include "aevol_version.h"
......@@ -47,15 +48,11 @@ using namespace aevol;
// Helper functions
void print_help(char* prog_path);
void interpret_cmd_line_options(int argc, char* argv[]);
std::tuple<std::string, std::string> interpret_cmd_line_options(int argc, char* argv[]);
std::list<std::string> read_sequence_file(const std::string& chromosome_file_name);
// Command-line option variables
static std::string param_file_name;
static std::string chromosome_file_name;
int main(int argc, char* argv[]) {
interpret_cmd_line_options(argc, argv);
const auto [param_file_name, chromosome_file_name] = interpret_cmd_line_options(argc, argv);
// Print the hash and date of the commit used to compile this executable
printf("Running aevol version %s\n", version_string);
......@@ -124,7 +121,11 @@ void print_help(char* prog_path) {
printf("\tload chromosome from given text file instead of generating it\n");
void interpret_cmd_line_options(int argc, char* argv[]) {
std::tuple<std::string, std::string> interpret_cmd_line_options(int argc, char* argv[]) {
// Define allowed options
const char* options_list = "hVf:C:r:";
static struct option long_options_list[] = {
......@@ -168,6 +169,8 @@ void interpret_cmd_line_options(int argc, char* argv[]) {
if (param_file_name.length() == 0) {
param_file_name = DEFAULT_PARAM_FILE_NAME;
return std::make_tuple(param_file_name, chromosome_file_name);
auto read_sequence(std::ifstream& chromosome_file, const std::string& chromosome_file_name) {
