Commit 2494be0d authored by Vincent Liard's avatar Vincent Liard
Update the `README` file
Update the indications in the README file to somehow help
new user get Aevol compiled and started. This is certainly
not a full guide, but hopefully a collection of clues.
parent 93d5efd2
...@@ -30,28 +30,35 @@ distributions. Please visit www.aevol.fr ...@@ -30,28 +30,35 @@ distributions. Please visit www.aevol.fr
To take a quick tour, please take the following steps: To take a quick tour, please take the following steps:
1) install aevol 1) Compile Aevol with the following commands:
cd into the main dir cd aevol/build
./configure cmake .
make make
sudo make install
(see INSTALL in the main dir or run ./configure --help for more information) In that process, you'll need development packages.
Here are the basic dependencies on a Debian system:
build-essential
cmake
zlib1g-dev
libboost-dev
libx11-dev
libboost-filesystem1.67-dev
One option to install them all at once is to run the following command:
sudo apt install build-essential cmake zlib1g-dev libboost-dev libx11-dev libboost-filesystem1.67-dev
NOTE: If you don't have sudo rights or simply don't want to install aevol 2) To run an example, e.g. basic, assuming you're in Aevol's root directory:
just yet, skip the "sudo make install" step and run the executables "locally" cd examples/basic
with ../../src/aevol_create and ../../src/aevol_run ../../build/bin/aevol_create
../../build/bin/aevol_run
2) To run an example, cd into it then run:
aevol_create
aevol_run
The first command will create an experiment with the parameters contained The first command will create an experiment with the parameters contained
in the "param.in" file in the "param.in" file
The second command will launch the simulation for 1000 generations The second command will launch the simulation for 1000 generations
(use --nbgener XXX or -n XXX to run for XXX generations) (otherwise, use the --nb_timesteps option to specify the desired number of
generations)
For more information, please see the manpages (e.g. man aevol_create), run any For more information, please see the manpages in the `doc` directory
executable with the -h option (e.g. aevol_create -h) and ultimately visit (e.g. man -l aevol_create.1),
www.aevol.fr or run any executable with the --help option
(e.g. aevol_create --help),
and ultimately visit www.aevol.fr
