Commit 13cbd354 authored by LUISELLI Juliette's avatar LUISELLI Juliette Committed by David Parsons
create new compilation option
parent fe70661c
...@@ -35,6 +35,7 @@ set(disable-multi-promoters "" CACHE STRING "Forbid that a gene is translated by ...@@ -35,6 +35,7 @@ set(disable-multi-promoters "" CACHE STRING "Forbid that a gene is translated by
set(dna-factory-alg "L2G" CACHE STRING "Which memory allocation algorithm to use for managing the DnaFactory pool of DNAs") set(dna-factory-alg "L2G" CACHE STRING "Which memory allocation algorithm to use for managing the DnaFactory pool of DNAs")
set(with-triangle OFF CACHE BOOL "Whether to enable triangle phenotypic target (else Gaussian)") set(with-triangle OFF CACHE BOOL "Whether to enable triangle phenotypic target (else Gaussian)")
set(with-eukaryote OFF CACHE BOOL "Whether to enable eukaryotic version")
set(with-detectclone ON CACHE BOOL "Whether to enable clones and not recompute them") set(with-detectclone ON CACHE BOOL "Whether to enable clones and not recompute them")
set(with-floatconcentration OFF CACHE BOOL "Whether to enable the encoding of concentration has float (and not double)") set(with-floatconcentration OFF CACHE BOOL "Whether to enable the encoding of concentration has float (and not double)")
set(with-perf-traces OFF CACHE BOOL "Whether to activate performance traces of (R-)Aevol") set(with-perf-traces OFF CACHE BOOL "Whether to activate performance traces of (R-)Aevol")
...@@ -150,6 +151,10 @@ if ( ${with-triangle} ) ...@@ -150,6 +151,10 @@ if ( ${with-triangle} )
add_definitions(-DPHENOTYPIC_TARGET_TRIANGLE) add_definitions(-DPHENOTYPIC_TARGET_TRIANGLE)
endif () endif ()
if ( ${with-eukaryote} )
add_definitions(-D__EUKARYOTE)
endif ()
if ( ${with-detectclone} ) if ( ${with-detectclone} )
add_definitions(-D__DETECT_CLONE) add_definitions(-D__DETECT_CLONE)
endif () endif ()
