Commit ac46c992 authored by Jens Gustedt's avatar Jens Gustedt
remove unused local variables
parent 83cb84c0
...@@ -1066,9 +1066,7 @@ atomic_exchange_explicit((OBJP), (DESIRED), memory_order_seq_cst) ...@@ -1066,9 +1066,7 @@ atomic_exchange_explicit((OBJP), (DESIRED), memory_order_seq_cst)
p99_extension \ p99_extension \
P99_MACRO_PVAR(p00_objp, (OBJP), volatile); \ P99_MACRO_PVAR(p00_objp, (OBJP), volatile); \
typedef __typeof__(P00_AT(p00_objp)) p00_base_t; \
typedef __typeof__(P00_AX(p00_objp)) p00_ubase_t; \ typedef __typeof__(P00_AX(p00_objp)) p00_ubase_t; \
typedef __typeof__(P00_AM(p00_objp)) p00_mbase_t; \
register p00_ubase_t p00_ret = P99_INIT; \ register p00_ubase_t p00_ret = P99_INIT; \
if (!atomic_is_lock_free(p00_objp)) { \ if (!atomic_is_lock_free(p00_objp)) { \
P99_SPIN_EXCLUDE(&p00_objp->p00_lock) \ P99_SPIN_EXCLUDE(&p00_objp->p00_lock) \
...@@ -1167,9 +1165,7 @@ p99_extension ...@@ -1167,9 +1165,7 @@ p99_extension
P99_MACRO_VAR(p00_desp, (DES)); \ P99_MACRO_VAR(p00_desp, (DES)); \
register p00_ubase_t const p00_des = { .p00_t = (p00_desp) }; \ register p00_ubase_t const p00_des = { .p00_t = (p00_desp) }; \
