Commit 40be739b authored by Ludovic Courtès's avatar Ludovic Courtès
environment: Pass 'git-predicate' the right directory.
* environment.scm: Use (current-source-location) instead of "." as the
basis of the current directory name.
parent ae8d56d0
...@@ -38,7 +38,10 @@ ...@@ -38,7 +38,10 @@
(name "guix-kernel") (name "guix-kernel")
(version "0.0.1") (version "0.0.1")
(source (local-file "." "guix-kernel" (source (local-file "." "guix-kernel"
#:select? (git-predicate (getcwd)) #:select? (git-predicate
(dirname (assoc-ref
'filename)))
#:recursive? #t)) #:recursive? #t))
(build-system gnu-build-system) (build-system gnu-build-system)
(arguments (arguments
