Commit c4fd6f7d authored by Roberto Di Cosmo's avatar Roberto Di Cosmo
Add condensed Scilab
parent 309ec497
...@@ -2,7 +2,8 @@ ...@@ -2,7 +2,8 @@
\usepackage{a4wide} \usepackage{a4wide}
\usepackage{hyperref} \usepackage{hyperref}
\usepackage[datamodel=software,backend=biber]{biblatex} \usepackage[datamodel=software,backend=biber]{biblatex}
\addbibresource{sample.bib} \addbibresource{biblio.bib}
\addbibresource{manual.bib}
\input{softwarebib} \input{softwarebib}
\author{Inria Software Citation Working Group} \author{Inria Software Citation Working Group}
\date{\today} \date{\today}
...@@ -15,10 +16,11 @@ This is how the proposed entries are rendered with the standard BibLaTeX style ...@@ -15,10 +16,11 @@ This is how the proposed entries are rendered with the standard BibLaTeX style
extended with the \texttt{software} module. extended with the \texttt{software} module.
\begin{itemize} \begin{itemize}
\item sofware entry CGAL \cite{cgal} and Scilab \cite{delebecque:hal-02090402} \item software entry CGAL \cite{cgal} and Scilab \cite{delebecque:hal-02090402}
\item sofwareversion entry CGAL 5.0.2 \cite{cgal:5-0-2} and Scilab 1.1.1 \cite{delebecque:hal-02090402v1} \item softwareversion entry CGAL 5.0.2 \cite{cgal:5-0-2}
\item sofwaremodule entry Voronoi: from the chain of crossrefs \cite{cgal:lp-gi-20a}, and the from the condensed bibtem \cite{cgal:lp-gi-20a-condensed} (they should be identical) \item softwareversion Scilab 1.1.1 : from the chain of crossrefs \cite{delebecque:hal-02090402v1}, and from the condensed bibtem \cite{delebecque:hal-02090402-condensed} (they should be identical)
\item sofware entry Parmap \cite{parmap} \item softwaremodule entry Voronoi: from the chain of crossrefs \cite{cgal:lp-gi-20a}, and the from the condensed bibtem \cite{cgal:lp-gi-20a-condensed} (they should be identical)
\item software entry Parmap \cite{parmap}
\item codefragment entry simplemapper \cite{simplemapper} \item codefragment entry simplemapper \cite{simplemapper}
\item documentation in a software entry \cite{scilabdoc} \item documentation in a software entry \cite{scilabdoc}
\end{itemize} \end{itemize}
