Commit fe39df46 authored by Samir Noir's avatar Samir Noir :cheese:
collapse
parent 48711b24
Pipeline #400343 passed
...@@ -20,14 +20,14 @@ class OarsubSimplifierAliasesGenerator < WikiGenerator ...@@ -20,14 +20,14 @@ class OarsubSimplifierAliasesGenerator < WikiGenerator
@generated_content = "__NOEDITSECTION__\n" @generated_content = "__NOEDITSECTION__\n"
@generated_content += "=== Clusters and nodes ===\n" @generated_content += "=== Clusters and nodes ===\n"
@generated_content += "<code>%d</code> represent a node's number.\n" @generated_content += "<code>%d</code> represent a node's number.<br/><br/>\n"
@generated_content += "{|class=\"wikitable\"\n"
@generated_content += "! style=\"width: 15%\" | Alias\n"
@generated_content += "! style=\"width: 30%\" | Description\n"
@generated_content += "! style=\"width: 30%\" | Translate to\n"
@generated_content += "! style=\"width: 30%\" | Site\n"
sites_aliases.each do |site, aliases| sites_aliases.each do |site, aliases|
@generated_content += "'''#{site.capitalize}'''\n"
@generated_content += "{|class=\"wikitable mw-collapsible mw-collapsed\"\n"
aliases.each do |al, value| aliases.each do |al, value|
desc = if al.match(/([a-zA-Z]+)-\%d/) desc = if al.match(/([a-zA-Z]+)-\%d/)
"Select a node from cluster #{$1.capitalize}" "Select a node from cluster #{$1.capitalize}"
...@@ -39,11 +39,10 @@ class OarsubSimplifierAliasesGenerator < WikiGenerator ...@@ -39,11 +39,10 @@ class OarsubSimplifierAliasesGenerator < WikiGenerator
@generated_content += "|#{al}\n" @generated_content += "|#{al}\n"
@generated_content += "|#{desc}\n" @generated_content += "|#{desc}\n"
@generated_content += "|<code>#{value}</code>\n" @generated_content += "|<code>#{value}</code>\n"
@generated_content += "|#{site}\n"
end end
@generated_content += "|}\n"
@generated_content += "\n"
end end
default_aliases_by_category.sort.each do |cat, data| default_aliases_by_category.sort.each do |cat, data|
@generated_content += "=== #{cat} ===\n" @generated_content += "=== #{cat} ===\n"
