Commit fd27f02f authored by Lucas Nussbaum's avatar Lucas Nussbaum
Since the oar properties generator has been switched to using...
Since the oar properties generator has been switched to using load_data_hierarchy, the wiki generator for oar-properties must follow
parent 27199f59
Loading
Checking pipeline status
Loading
