GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
efafd43e
efafd43e
9 years ago
Jérémie Gaidamour
Downloads
Patches
[dev] Consider both mounted and mountable interfaces
fe5286eb
generators/oar-properties/lib/lib-oar-properties.rb
+8
-8
8 additions, 8 deletions
8 additions
8 deletions
8
8
efafd43e
@@ -38,32 +38,32 @@ def get_node_properties(cluster_uid, cluster, node_uid, node)
h
'cputype'
node
'processor'
'model'
node
'processor'
'version'
join
h
'cputype'
node
'processor'
'model'
node
'processor'
'version'
join
h
'cpufreq'
node
'processor'
'clock_speed'
1_000_000_000.0
h
'cpufreq'
node
'processor'
'clock_speed'
1_000_000_000.0
h
'disktype'
node
'block_devices'
first
'interface'
h
'disktype'
node
'block_devices'
first
'interface'
h
'ethnb'
node
'network_interfaces'
values
select
na
na
'interface'
/ethernet/i
select
nb
nb
'mountable'
true
length
h
'ethnb'
node
values
select
na
na
'interface'
/ethernet/i
select
nb
nb
'mounted'
true
nb
'mountable'
true
length
eth10g
node
values
select
na
na
'interface'
/ethernet/i
select
nb
nb
'mountable'
true
eth10g
node
values
select
na
na
'interface'
/ethernet/i
select
nb
nb
'mounted'
true
nb
'mountable'
true
h
'eth10g'
eth10g
detect
na
na
'rate'
10_000_000_000
nil?
false
true
h
'eth10g'
eth10g
detect
na
na
'rate'
10_000_000_000
nil?
false
true
ib10g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mountable'
true
na
'rate'
10_000_000_000
ib10g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mounted'
true
na
'mountable'
true
na
'rate'
10_000_000_000
h
'ib10g'
ib10g
true
false
h
'ib10g'
ib10g
true
false
h
'ib10gmodel'
ib10g
ib10g
'version'
'none'
h
'ib10gmodel'
ib10g
ib10g
'version'
'none'
ib20g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mountable'
true
na
'rate'
20_000_000_000
ib20g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mounted'
true
na
'mountable'
true
na
'rate'
20_000_000_000
h
'ib20g'
ib20g
true
false
h
'ib20g'
ib20g
true
false
h
'ib20gmodel'
ib20g
ib20g
'version'
'none'
h
'ib20gmodel'
ib20g
ib20g
'version'
'none'
ib40g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mountable'
true
na
'rate'
40_000_000_000
ib40g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mounted'
true
na
'mountable'
true
na
'rate'
40_000_000_000
h
'ib40g'
ib40g
true
false
h
'ib40g'
ib40g
true
false
h
'ib40gmodel'
ib40g
ib40g
'version'
'none'
h
'ib40gmodel'
ib40g
ib40g
'version'
'none'
ib56g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mountable'
true
na
'rate'
56_000_000_000
ib56g
node
values
detect
na
na
'interface'
/infiniband/i
na
'mounted'
true
na
'mountable'
true
na
'rate'
56_000_000_000
h
'ib56g'
ib56g
true
false
h
'ib56g'
ib56g
true
false
h
'ib56gmodel'
ib56g
ib56g
'version'
'none'
h
'ib56gmodel'
ib56g
ib56g
'version'
'none'
myri10g
node
values
detect
na
na
'interface'
/myri/i
na
'mountable'
true
na
'rate'
10_000_000_000
myri10g
node
values
detect
na
na
'interface'
/myri/i
na
'mounted'
true
na
'mountable'
true
na
'rate'
10_000_000_000
h
'myri10g'
myri10g
true
false
h
'myri10g'
myri10g
true
false
h
'myri10gmodel'
myri10g
myri10g
'version'
'none'
h
'myri10gmodel'
myri10g
myri10g
'version'
'none'
myri2g
node
values
detect
na
na
'interface'
/myri/i
na
'mountable'
true
na
'rate'
2_000_000_000
myri2g
node
values
detect
na
na
'interface'
/myri/i
na
'mounted'
true
na
'mountable'
true
na
'rate'
2_000_000_000
h
'myri2g'
myri2g
true
false
h
'myri2g'
myri2g
true
false
h
'myri2gmodel'
myri2g
myri2g
'version'
'none'
h
'myri2gmodel'
myri2g
myri2g
'version'
'none'
This diff is collapsed.
Loading
Save comment
