Commit ef23d254 authored by LOUP David's avatar LOUP David
[lyon] Update network description between gw and salome
parent e3e9b2de
Pipeline #148876 passed
......@@ -94,12 +94,12 @@
"uid": "alcor"
"kind": "switch",
"port": "2",
"snmp_name": "ethernet1/1/23",
"uid": "salome"
"kind": "switch",
"port": "1",
"snmp_name": "ethernet1/1/24",
"uid": "salome"
"kind": "switch",
......@@ -11,14 +11,12 @@
"kind": "node",
"port": "eth1",
"ports": [
"kind": "router",
"port": "0:23",
"snmp_name": "GigabitEthernet2",
"port": "0:24",
"snmp_name": "GigabitEthernet1",
"uid": "gw"
......@@ -26,7 +24,7 @@
"kind": "other",
"port": "eth1",
"snmp_name": "GigabitEthernet4",
"snmp_name": "GigabitEthernet3",
"uid": "sw-admin"
......@@ -61,6 +59,8 @@
"kind": "node",
"port": "eth1",
......@@ -100,10 +100,10 @@ gw:
22:
uid: alcor
kind: server
23:
24:
uid: salome
kind: switch
port: '2'
port: '1'
25:
snmp_pattern: 'ethernet1/1/25:1'
uid: force10
......@@ -32,11 +32,11 @@ salome:
rate: 1000000000
port: eth1
ports:
2:
1:
uid: gw
kind: router
port: "0:23"
4:
port: "0:24"
3:
uid: sw-admin
kind: other
21: sagittaire-1
